The discussion centers on the load-carrying behavior of shells, specifically focusing on the local and global effects of positive and negative curvature. Participants inquire about relevant literature and resources, suggesting references like the ASME Boiler and Pressure Vessel code and Roark's formulas. The original poster is using ANSYS to analyze displacement and stress under various loading conditions and is seeking additional academic resources. Recommendations for books on finite element analysis and shell behavior are shared, emphasizing the importance of genuine reviews when selecting literature. The conversation highlights the need for comprehensive resources to understand the complexities of shell mechanics.
#1
elena
Does anyone has some literature or any idea about this topic?More precisely i would like to know about the local and global effects due to neative and positive curvature.Thanks!
Can you be more specific? Have you looked at ASME Boiler and Pressure Vessel code? Have you looked at Roark's? What kind of loading conditions are you looking at?
Do you mean bending behavior of shells under loads?? what approach are you looking for? finite element analysis?
#4
elena
I mean local and global effects of a single load for different types of shells.That is for shells with different Gaussian quadrature.The boundary conditions don't matter as in i set for example clamped bc's.I can see the local and global effects (displacement,stresses...) in ANSYS that I am working but i would like to have some literatureon this subject.Thanks and I hope I explained it better this time.
I spoke to some friends for a recommendation of a book, but they didn't give know. Anyway, when I'm looking for a book on an specific subject i usually just check in amazon and look for what it seems like genuine reviews. I looked your topic and i saw a FEA and Shells behaviour, maybe you should check that book. Good luck.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes?
However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two.
The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
