Load line of transistor question
To draw the load line of a transistor, it is essential to determine the saturation current and the collector-base voltage when the collector current is zero. The base-emitter junction is typically forward biased at around 0.6 to 0.7 volts, while the base-collector junction should be reverse biased to achieve accurate load line representation. The load line itself is derived from the circuit configuration and is a straight line formed by plotting the supply voltage against the current through a resistive load. The relationship between collector current (Ic) and collector-emitter voltage (Vce) is expressed through the equation Vcc = Vce + IcRc, which helps in plotting the load line on the transistor's characteristic curves. Understanding these principles is crucial for analyzing transistor behavior in various circuit configurations.
Outrageous
In order to draw the load line of transistor, we have to find out the saturation current (where the voltage is minimum or zero) and voltage of collector-base when collector current is zero.
In order to calculate maximum saturation current, we have to forward biased the base-emitter, and reverse biased the base -collector and then get the voltage of collector-emitter to be zero(V of collector minus voltage of emitter equals to zero), right??
Thank you
I think 'we have to forward biased the base-emitter, and reverse biased the base' instead of both forward because when we forward both we can't get a constant curve at saturation region, correct?
the base-emitter junction is always forward biased as long as the transistor is not in full "cut-off" (where the collector current is zero). so, from the POV of the load line, the base-emitter is forward biased, usually by about 0.6 volts.
what is POV?
The base-emitter is usually 0.7V.
How to draw a load line?
Outrageous said:
what is POV?
POV = "point of view"
Maybe this will help:
First of all there is not one load line for a transistor.
There are many and they depend upon the circuit configuration.
Having said that, for a resistive load the load line is a straight line so you only need to find two points and join them to be able to draw one.
To draw a load line for R ohms on the collector current (y axis) v collector voltage (x axis) curves:
1)Locate the point of the voltage axis corresponding to the supply voltage.
2)Locate the point on the current axis which the supply voltage would drive through R ohms.
3) Join these two points to form the load line for R ohms.
go well
Thank you, understand already.
okay. whatever. from long ago, when i was a graduate teaching assistant (and i was teaching a lab), it was most often 0.6v for silicon.
well, your transistor curve is that of a function I_c as a function of V_{ce} for various I_b. so given an I_b, you still don't know what I_c is without also knowing V_{ce}. the load line is another equation that relates I_c and V_{ce}. and that equation comes from the rest of the circuit (assuming no R_e:
V_{cc} = V_{ce} + I_c R_c
or
I_c = \frac{1}{R_c} ( V_{cc} - V_{ce} )
plotting that equation on top of the transistor curves is your load line.
or
Understand.
when there is R_e ,we can use the equation in this (transistor load line)
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/loadline.html
But for this case , our Ic=Ib, correct?
