Localizing an electron problem ()
  • Thread starter Thread starter jakepeck
    Electron
The discussion revolves around localizing an electron using visible light and the implications of the uncertainty principle on its momentum. The initial approach involved using the speed of light to estimate the time for an electron to traverse the size of Ann Arbor, but it was pointed out that electrons cannot travel at the speed of light. The participant recalculated using the uncertainty principle and the wavelength of yellow light, leading to a corrected estimate of the electron's speed and time. Ultimately, the final calculation suggested that it would take approximately 94.56 seconds for the electron to cover the distance of Ann Arbor, which was deemed reasonable. The conversation highlights the importance of correctly applying quantum mechanics principles in problem-solving.
jakepeck
Suppose I use visible (say yellow) light to observe an electron.
Roughly speaking, I will then be able to localize the electron to a region
about the size of the wavelength of the light. According to the
uncertainty principle, I am now limited as to how well I know the momentum
of the electron. If the maximum momentum that the electron can have is
roughly equal to the uncertainty of the momentum, about how long will I
have to wait so that the electron could be anyplace in the City of Ann
Arbor? To do this, you will need to estimate the size of Ann Arbor, and
calculate how long it would take the electron to go a distance about that
size.
I chose D = Rt and A = pi(R^2)
I just decided to use an area equation, pretending Ann Arbor is a circular town, using a given area of 27 miles.
Then I just used D = rt to find the time it would take the electron to go that distance, not completely sure if that was the right thing to do. I used c as the speed assuming the electron goes that speed... Is that maybe where my problem is wrong?
my answer was t = 3.15 x 10^(-5) seconds.
Please help, this is killing meeeeeee!
jakepeck said:
I used c as the speed assuming the electron goes that speed... Is that maybe where my problem is wrong?!
That's certainly it! Electrons can't travel at c! Use the uncertainty principle to find the uncertainty in the momentum, and thus the uncertainty in the electrons speed, and go from there.
Am I supposed to use deltaXdeltaP = h ? What equation am I supposed to use? I see a lot of different equations for this.
Nearly,
Delta x Delta p >= hbar/2
Alright, I used deltaXdeltaP >= hbar/2 and brought it down to
9436.4 meters(9.109x10^(-31)kg)v>=hbar/2
which gave me v >= 6.134 x 10^(-9) m/s
so i plugged that back into D = rt
9436.4 = (6.134x10^(-9))t
t = 1.54 x 10^12 seconds
Is this right?
Is this right?
9436.4 meters doesn't sound like the wavelength of yellow light to me!
I used the distance of ann arbor... But I guess I am supposed to use the wavelength of the light in this case? 580 nm for yellow light?
Well, the uncertainty in the position is the wavelength of the light. So, yes.
Edited to add - this is a really strange question, I have to say.
ok this time I did
5.8 x 10^(-4)(9.109 x 10^(-31))v >= hbar
which lead me to v >= 9.975 x 10^(-24)
plugged into D = rt
9436.4 m = (9.975 x 10^(-24))t
t= 9.46 x10^(26) s
And yes, this is my professor at University of Michigan, a weird dude.
5.8 x 10^(-4) is not equal to 580nm
I thought there was 1,000,000 nm in a meter? 580 nm X 1 meter / 1,000,000 nm = 5.8 x 10^(-4) m
Try another 3 orders of magnitude. 1nm = 1*10^-9 m
ahahha oops okay...
now after plugging everything in the same way but with the new wavelength...
v >= 99.79 m/s
which leads me to t = 94.56 seconds
Did I finally make it?
No idea. I haven't calculated it myself!
Does the answer seem reasonable to you?
I think it sounds pretty reasonable, as Ann Arbor is decently sized. 94 seconds sounds about right.
