How to find the absolute extrema of a function on a given interval?
In summary, the absolute minimum and the absolute maximum of the function f(x) = -x^2 + 3x occur on the interval [0, 3].
domyy
196
Locate the absolute extrema of the given function on the indicated interval.
f(x) = -x^2 + 3x ; interval: [0 , 3 ]
f'(x) => -2x + 3x = 0
=> x = 0
f(0) = -(0)^2 + 3(0) = 0
f(3) = -(3)^2 + 3(3) = 0
My answer: Absolute minimum (0,0) and (3,0)
Now, my book gives the following answer for the problem above:
Minima: (0, 0) and (3, 0)
Maximum: (3/2) and (9/4)
Where does 3/2 and 9/4 come from?
Your derivative is incorrect. Specifically, this part:
[tex]\frac{d}{dx}3x[/tex]
=> x = 0
You have only found the minima; you also need to find the maximum.
RGV
Ok, I have:
f'(x) = -2x + 3(1) = 0
= -2x = -3
x = 3/2
ohh I understand now!
Thank you so much!
I just have another question: On my notes, I see I should find the critical point. It says that for that, the derivative = 0 or the derivative is undefined.
But in this case, wouldn't -3/2 be the critical point?
What's confusing me is that I have the following on my notes:
f(x) = 2(3 - x) ; interval [ -1, 2]
differentiating: 6 - 2x = 0
0 - 2x = 0
x = -0/2
Now, why 2x wasn't differentiated and written as 2(1) ?
0 - 2x = 0
x = -0/2
If this is what you have written in your notes, your notes are a mess. The derivative of 6 - 2x is not -2x.
RGV
How about the critical point? Where's the critical point for the first problem?
I can't have copied everything wrong. I have two other problems that I copied from the blackboard that follow the same thought:
Look at this one:
-x^2 + 3x ; interval [0,3]
=> -x^2 + 3x = 0
=> -2x + 3x = 0
=> x = 0
Another problem:
f(x) = x^3 - 3x^2; interval: [-1,3]
3x^2 - 6x = 0
6x - 6x = 0
x = 0
It seems that x should always be 0 or undefined because that is what I have on my notes:
"A critical point is an interior point of the domain of f where f' is zero or f' is undefined."
domyy said:
I can't have possibly copied everything wrong. I have two other problems that I copied from the blackboard that follow the same thought:
Look at this one:
=> -x^2 + 3x = 0
Why are you setting -x2 + 3x to zero?
domyy said:
=> -2x + 3x = 0
This is wrong.
Let's start from the beginning...
f(x) = -x2 + 3x, on [0, 3]
f'(x) = d/dx(-x2 + 3x) = ? (It's NOT -2x + 3x!)
f'(x) = 0 => ? = 0
An important point that you seem to be missing is that maxima or minima can occur at these places:
1. Numbers in the domain at which the derivative is zero.
2. Numbers in the domain at which the original function is defined, but the derivative is undefined.
3. Endpoints of the domain.
domyy said:
=> x = 0
Another problem:
3x^2 - 6x = 0
6x - 6x = 0
What are you doing?
domyy said:
x = 0
Your notes are wrong.
domyy said:
A critical point is on interior point of the domain of f where is zero or f' is undefined.
Ohhh I got it! I thought this was part of my notes but I just realized that it was me trying to do the homework that thought I had understood. I decided to do my homework right next to my notes...bad choice...I am sorry!
I have just one example on my notes about this. This is a simple exercise that i can't get. Could someone PLEASE do -x^3 + 3x intervals (0,3) so that I can finally understand the steps I need to take in this problem ?? Please I still have 10 questions to answer and i can't get through the first one.
Anyone?
Anyone available?
Ok. First, what is:
[tex]\frac{d}{dx} (-x^3+3x)[/tex]
-3x^2 + 3
What steps should I take from here?
Thank you so much for replying!
What steps did you take in other problems like this one (i.e., the other problems that people have already helped you with)? Just do the same types of steps on this one.
RGV
Here I was told that I shouldn't have it " = 0 " then, what's the right way to do it?
f(x) = -x3 + 3x, on (0, 3)
f'(x) = -3x2 + 3
f'(x) = 0 => -3x2 + 3 = 0 => -3(x2 - 1) = 0
=> x = ?
Told by whom?
"Shouldn't have it = 0" - what is it?
I have the following exercise:
f(x) = 2(3-x); [-1,2] FIND ABSOLUTE EXTREMA
So, f(x) = 6 - 2x
f'(x) = -2
f'(-1) = 2(3+1) = 8 ; (-1,8) Maximum
f'(2) = 2(3-2) = 2 ; (2,2) Minimum
________________________________________________________
Another exercise:
My trouble is that I am trying to find one model to solve all problems relating to this topic but in the following exercise I find the Maximum differently:
f(x) = -x^2 + 3x; [ 0, 3]
f'(x) = -2x + 3
f'(0) = -(0)^2 + 3(0) = 0 ; (0,0)
F'(3) = -(3)^2 + 3(3) = 0 ; (3,0)
Minimum => (0,0) and (3,0)
f'(x) = -2x + 3
f'(0) = 0 => -2x + 3 = 0
x = 3/2
-(3/2)^2 + 3(3/2) = 9/4
In this case, I found the maximum differently (3/2, 9/4)
Now, is it because the first exercise f'(x) = -2 ? And what does it mean? What does "f'(x) = -2x + 3" mean compared to "f'(x) = -2" ?
Would it be that every time my f'(x) = a constant, I'll be able to find my Maximum and Minimum by plugging the intervals given in the function and when it does not equal a constant, I'll have to solve it the way I did in the last example?
I think I am sort of understanding this. I did the following exercise:
f(x) = x^3 - 3x^2 ; (-1, 3)
f'(x) = 3x^2 - 6x
f'(-1) = (-1)^3 - 3(-1)^2 = -4 ; (-1,-4)
f'(3) = (3)^3 - 3(3)^2 = 0 ; (3,0)
f'(x) = 0 => 3x^2 - 6x = 0
=> 3x(x-2)
=> 3x = 0 ; x -2= 0 , so x=2
(0)^3 - 3(0)^2 = 0 ; (0,0)
(2)^3 - 3(2)^2 = 8 - 3(4) = -4; (2,-4)
MIN = (-1,-4) and (2,-4)
MAX = (0,0) and (3,0)
f'(x) = 3x^2 - 6x
=> 3x(x-2)
Evaluate f(x) at the ends of your interval, not f'(x).
Set f'(x) = 0 to find some critical point(s), which you did do here.
Also, for a sanity check, graph the function.
Thank you for your reply!
I am having trouble with the exercise f(x) = 3x^2/3 - 2x ; (-1,1)
I already found (-1,5) and (1,1) by plugging the intervals back into the function.
But I have f'(x) = 2x^-1/3 -2 = 0
Now, I am having trouble finding the answer. I found 1 which would give me (1,1).
However, the answer should be MIN (0,0) and MAX (-1,5). And I don't understand it.
f'(x) = 3x^2 - 6x
=> 3x(x-2)
Normally, that's what you would do, but for this problem, the function is defined on an open interval. The numbers -1 and 3 are not in the domain.
You need parentheses around the exponent. This is what you wrote:
f(x) = ## \frac{3x^2}{3} - 2x##
This is what I think you meant
f(x) = 3x2/3- 2x
Without using LaTeX or the HTML tags that I used, you can write it this way:
f(x) = 3x^(2/3) - 2x
But -1 and 1 aren't in the domain.
Again, you need parentheses. This is f'(x) = 2x^(-1/3) - 2
From an earlier post:
Mark44 said:
Maxima or minima can occur at these places:
1. What is the definition of absolute extrema?
Absolute extrema refers to the maximum and minimum values of a function over a given interval. These values are the highest and lowest points on the graph of the function.
2. How do you locate absolute extrema?
To locate absolute extrema, you must first find the critical points of the function by setting the derivative equal to zero. Then, evaluate the function at each critical point and the endpoints of the given interval. The highest and lowest values will be the absolute extrema.
3. Can there be more than one absolute extrema for a function?
Yes, a function can have multiple absolute extrema, as long as they occur at different points on the graph. For example, a function may have both a maximum and a minimum value over a given interval.
4. Are absolute extrema always present on a graph?
No, absolute extrema are not always present on a graph. It is possible for a function to have no absolute extrema if it is a constant function, or if the function is undefined at the given interval.
5. What is the significance of finding absolute extrema?
Finding absolute extrema allows us to determine the overall behavior and trends of a function. It can also help us make predictions and solve real-world problems related to the function.
