How to Simplify Logarithmic Equations?
  • Thread starter Thread starter JakePearson
    Log
To simplify logarithmic equations, it's essential to apply the laws of logarithms, such as log_a(xy) = log_a(x) + log_a(y) and log_a(x^y) = y log_a(x). For the given problems, users are encouraged to break down each expression into simpler components. The discussion emphasizes the importance of understanding the properties of logarithms to effectively simplify expressions like log_3(27x^2) and ln(x^2/y^2). Participants are prompted to share their attempts at solving these equations for better guidance. Mastery of these logarithmic rules is crucial for successfully simplifying complex logarithmic expressions.
JakePearson
i need help with the following quesitons;
a) log_3 27x^2
b) ln (x^2 / y^2)
c) ln (xe^x)
d) log (2x + 3y)
i don't mind if you could direct me in the right direction and i will do my best to go from there :)
USING THE RULES FOR LOGS, SPLIT THE FOLLOWING UP INTO SEPERATE LOGARITHM FUNCTIONS AND NUMBERS AS MUCH AS POSSIBLE?
a) log_3 27x^2
b) ln (x^2 / y^2)
c) ln (xe^x)
d) log (2x + 3y)
Depends on what x and y are. Could you please provide the full problem statement, and then show us your attempt at the solutions?
First, do you know the "laws of logarithms"?
log_a(xy)= log_a(x)+ log_a(y)
log_a(x^y)= ylog_a(x)
Also you should know that log_a(a^x)= x.
Using the rules for logs, split the following up into separate logarithm functions and numbers as much as possible?
Okay, so using the hints/review from HallsofIvy, show us your tries at simplifying those equations...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
