Logistic modeling - help integrating/solving for P
  • Thread starter Thread starter brusier
    Modeling
brusier
Sorry about the title; I accidentally hit enter instead of 'Shift'. It should read Logistic Modeling -- help integrating/solving for P
If P(0)=2, find P(90).
dP/dt=1/900P(9-P)
my solution looks like:
dP/(P(9-P))=1/900dt (seperable diff eq.)
1/9(ln(P)(9-P))=1/900 t+C (partial fractions and property ln M + ln N = ln MN)
lnP(9-P) = 1/100t+9C
P(9-P)= Ce^(1/100t) (exponentiated; 9C=C)
kinda stuck here (and I don't see how P ever stops growing.)
be careful with your brackets, its pretty hard to read what is in your log, divided etc.
but following through your method
\frac{1}{P(9-P)} = \frac{A}{P}+\frac{b}{9-P} = \frac{9A + (b-A)P}{P(9-P)}
giving A = 1/9, B = 1/9
so evaulating the integral
\int \frac{dP}{P(9-P)} = \frac{1}{9}(\int\frac{dP}{P}+\int\frac{dP}{9-P}) =\frac{1}{9}(ln(P) - ln(9-P)) +C = \frac{1}{9}ln(\frac{P}{9-P})+C
maybe you missed a negative...?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
