What are the Limits of Wavelength Detection in Modern Telescopes?
  • Stargazing
  • Thread starter Zman
  • Tags
    Telescope
In summary, the Lofar telescope is currently able to detect wavelengths as long as 7 meters, not 30 meters as originally thought. While there may be other telescopes in astronomy that can detect long wavelengths, they have not been a major focus as higher energy wavelengths are considered more exciting. One example of a telescope that can detect long wavelengths is the Cambridge (MRAO) pulsar array.
Zman
96
What are the longest wavelengths that todays telescopes can detect for?
Astronomy news on Phys.org
Probably something like lofar (10MHz = 30m)
I looked up the Lofar telescope on the web and in a slashdot comment;
http://science.slashdot.org/story/1...cope-Array-Grabs-First-Pulsar-Images?from=rss
it says that it is sensitive to wavelengths as long as 7 metres. Is this a mistake?
I can see that 10Mhz relates to a 30m wavelength.
Are there other telescopes in astronomy that can detect long wavelengths?
Probably the 10MHz band isn't built yet. I don't know if it's a particularly important part or just the ultimate limit of the antenna.
Generally long wavelengths haven't been much of a focus, high energy is more sexy.
Probably the most famous is the cambridge (MRAO) pulsar array.
The longest wavelengths that today's telescopes can detect for are in the radio and submillimeter range, with the largest telescopes capable of detecting wavelengths up to a few millimeters. These wavelengths are important for studying objects such as cold gas and dust in the universe, and for probing the earliest stages of galaxy formation. However, there are also plans for future telescopes, such as the Square Kilometer Array, which will be able to detect even longer wavelengths in the centimeter and meter range. These advancements in technology will allow us to further explore the mysteries of the universe and expand our understanding of the cosmos.
What is a "Longest Wavelength Telescope"?
A "Longest Wavelength Telescope" is a type of telescope that is designed to observe objects and phenomena that emit or reflect radiation with longer wavelengths, such as radio waves and infrared light. It differs from traditional optical telescopes, which are designed to observe visible light.
How does a Longest Wavelength Telescope work?
A Longest Wavelength Telescope works by using specialized detectors and receivers that are sensitive to longer wavelengths of radiation. It collects and focuses the radiation onto these detectors, which then convert the signals into images or data that can be analyzed by scientists.
What are some advantages of using a Longest Wavelength Telescope?
One major advantage of a Longest Wavelength Telescope is that it allows scientists to observe objects and phenomena that are not visible with traditional optical telescopes. This can provide important insights into the composition, temperature, and movement of these objects.
What are some limitations of a Longest Wavelength Telescope?
One limitation of a Longest Wavelength Telescope is that the images and data it collects may not be as detailed or clear as those from traditional optical telescopes. This is due to the longer wavelengths of radiation being more difficult to focus and interpret.
What types of objects can be observed with a Longest Wavelength Telescope?
A Longest Wavelength Telescope can observe a wide range of objects and phenomena, including planets, stars, galaxies, and even the cosmic microwave background radiation. It can also be used to study atmospheric phenomena on other planets and to detect radio signals from potential extraterrestrial civilizations.
  • Astronomy and Astrophysics
