Look of trajectory of a material point
The trajectory of the moving body is defined by the equations x(t)=At², y(t)=Bt, and z(t)=0, indicating that it lies entirely in the x-y plane. The velocity is derived as v=2At*i + B*j. The discussion suggests that the trajectory resembles a logarithmic function, but further analysis shows it can be expressed in standard form as y=B√(x/A). By converting from parametric to standard form, the trajectory is confirmed to be y=c√(x) where c combines the constants A and B. This provides a clearer understanding of the motion's path.
Chemist@
A body is moving, with the following data (these are all dependencies of the radius vector components respective to time): x(t)=At2, A>0; y(t)=Bt, B>0, z(t)=0. How does the trajectory of this movement look?
r=x(t)i+y(t)j+z(t)k
Velocity=dr/dt
r=At2*i+Bt*j (i,j and r are vectors)
Velocity=2At*i+B*j
Intuitively I think that the trajectory would look like a logarithm function, but is it correct and how to prove it?
Since z(t)=0 for all t the trajectory must lie entirely in the x-y plane. Did you try to sketch the trajectory? Pick arbitrary values for A and B and plot a few points. Alternatively, find y as a function of x and comment on the type of function it represents.
You may know already a type of motion which satisfies similar conditions.
I thought that it would look similar to y=log(x). Correct?
Similar it may be, but you can find the actual equation by converting from parametric form to standard y(x) = ... form.
Is it y=B*sqrt(x/A)?
Yup. Or if you combine the constants, ##y = c\sqrt{x}## .
