Troubleshooting a 0.28 and 0.216 Loop Antenna Transmit/Receive Issue
In summary: The loops are 1 meter apart. The testing frequency range is from 1kHz to 30MHz. Both of the antenna are 1-turn loops. I am using the setup described in IEEE-291-1991. It worked fine when my receiving antenna had the same radius as my transmit loop, but now that I am testing a smaller antenna, the results are questionable. I assume it would be best to use a transmit loop with the same sized loop, but that is too expensive and impractical.In summary, using a shorter antenna centered in relation to the transmit loop is recommended instead of level with the transmit loop.
Tisfurs
I am transmitting an electromagnetic field from a loop antenna of 0.28 radius to one with 0.216 radius. I know the antenna factor of the receiving antenna but when I add it to the measured field strength, it does not equal my calculated transmit field strength. Should the shorter antenna be centered in relation to the transmit loop or should it be level with the transmit antenna at the top of the loops, or the base of the antenna?
Welcome to the PF. How far apart are the antennas? You need to be in the far field in order to use the equations you are referring to.
In the far field, the antennas should be coplanar for the best transfer function.
Are you transmitting around 170MHz? How much power are you transmitting? What country are you in, and what licensed bands are near your transmit frequency?
With the loop sizes you described, the separation you are using, and the frequency range that you list, those are not antennas. They are just coupled inductors.
What are you intending to do, exactly?
Hmm, I just read through that IEEE spec that you cited:
http://www.scribd.com/doc/11355231/IEEE-Std-2911991
And it does say to use small loops and short, coaxial separation. Yuck. Are you using a shielded receiving loop?
What am I doing? Well, I am trying to validate loop antenna calibrations using a transmit loop antenna with a 0.28 radius to test the antenna factor of receive loop antennas of various radii. It works fine when they are similar in size but I'm having difficulty if the receive loop is significantly larger or smaller than the transmit loop. I'm trying to find any information that would guide me about the proper placement of the receive loop, particularly if it is much smaller than the transmit loop. And yes, they are all shielded loops.
I found the following link. Excellent article.
http://www.djmelectronics.com/articles/emc-antenna-parameters-p3.html
This covers antenna factor and a lot more.
I had to wonder if you are feeding the transmit antenna symmetrically?
For example, if you fed it directly with a coaxial cable, one end of the loop would be effectively earthed so the radiation would probably not be symmetrical.
If you rotate your coil by 180 degrees and get different results, the radiation is not symmetrical.
The reference above refers to using the test setup in an anechoic chamber to avoid reflections.
You might find the following site useful too. Not that it will fix your present problem, but it is a great calculator for large single turn loop inductance.
http://www.qsl.net/in3otd/ind1calc.html
The inductance of your large loop would be nearly 50% greater than that of your small loop.
1.48 uH vs 1.04 uH.
I did a check on the self resonant frequencies of your loops. The big one would resonate about 180 MHz and the small one would resonate at about 280 MHz, assuming a tube diameter of about 10 mm. So, this is sufficiently high in both cases to not matter.
This was done with Eznec, an antenna modelling program.
Does the shielding on your loops have a gap somewhere around the circumference? I think they are supposed to have this to avoid circulating currents in the shield.
Could you please post the antenna equations that you are trying to validate? Could you please also comment on electrically small "antennas" placed 1 m apart?
The loops have a gap at the top. BTW, I am not using an anechoic chamber. They are placed in a large open area with at least 3 meters of empty space behind each of them. The current applied to the transmit loop is being monitored with a current probe.
I wonder what sort of a result you are getting?
Do you get a steady rise in signal strength with increasing frequency?
Normally, when transmitting, the last thing you want to do is shield your antenna.
Would you consider trying it with two loops wound on opposite ends of a plastic drum? No shielding and just two equal diameter loops of heavy wire?
You didn't say if you were feeding the transmit loop symmetrically.
Yeah, the shielded loop antenna is a strange beast. But you pretty much have to use it when you are in the near field like this, to prevent E-field coupling. The shielded loop antenna is a B-field sensor (like they are used for sniffer probes in PCB EMI debug, for example).
The shield is broken at one point, somewhere around the circumference of the loop. This keeps it from being a shorted turn and excluding B-field from cutting the loop itself.
It is pretty alien. The original question started "I am transmitting an electromagnetic field from a loop antenna " but then the antenna is shielded so that it doesn't have any capacity coupling between the loops.
Can it be "electromagnetic" without any electric component? I don't know. Don't think so.
I think your first reaction that this is just magnetic coupling was about right.
I do know that a loop like that will parallel resonate at HF with quite a small capacitance across the feed point. If this happened, it would give a very non linear signal strength vs frequency graph.
That shielding could easily provide this capacitance if it wasn't very carefully grounded.
Good points. I wonder if it could work better with the TX antenna not shielded. But then again, he's still in the near field. I'm not real sure what that IEEE spec is intended for, but I didn't read it very closely either. Certainly all the antenna calibrations I've done have been in the far field; you too probably.
Yes, I think it would be worth a try to see if it works without the shields. I'd get rid of both shields and make new loops.
At least it would be an easy thing to try.
Not really sure what it is all about anyway.
The idea seems to be to make antennas that are equally useless at all frequencies tested and then see how well they communicate with each other. Pretty poorly, I'd guess. :)
Shielding them seems to be the icing on the cake. Like burying a dipole under 10 ft of Earth and trying to use it.
What could be causing the issue with my 0.28 and 0.216 loop antenna?
There are several possible reasons for this issue. The first thing to check is the connections between the antenna and the transmitter/receiver. Make sure they are secure and free of any damage. It's also important to check for any interference from nearby electronics or structures. If those things seem fine, the antenna itself may be damaged or malfunctioning.
How can I test if my 0.28 and 0.216 loop antenna is working properly?
The best way to test a loop antenna is to use a signal analyzer or spectrum analyzer. You can also try connecting the antenna to a different transmitter/receiver and see if the issue persists. Additionally, you can visually inspect the antenna for any physical damage or abnormalities.
What are some potential solutions to fix the issue with my 0.28 and 0.216 loop antenna?
If the issue is with the connections, make sure they are secure and undamaged. If there is interference, try moving the antenna to a different location or using shielding materials. If the antenna itself is damaged, you may need to repair or replace it. It's also a good idea to consult with a professional or reference the manufacturer's instructions for specific troubleshooting steps.
Can using the wrong frequency or transmission power affect the performance of my 0.28 and 0.216 loop antenna?
Yes, using the wrong frequency or transmission power can definitely affect the performance of your loop antenna. Make sure you are using the correct frequency and power settings for your specific antenna. If you are unsure, consult the manufacturer's instructions or seek professional guidance.
How can I prevent similar issues with my 0.28 and 0.216 loop antenna in the future?
To prevent similar issues, it's important to properly maintain and handle your loop antenna. Make sure all connections are secure and free of damage. Avoid placing the antenna near any potential sources of interference. It's also a good idea to regularly check and test the antenna to catch any potential issues early on.
  • Electrical Engineering
  • Astronomy and Astrophysics
12K
  • Classical Physics
