Loop released from rest and allowing to fall.
  • Thread starter Thread starter ANON
    Fall Loop Rest
ANON
The plane of a 20cm x 20cm metal loop with a mass of 10g and a resistance of 0.010 ohms is oriented vertically. A 1.0 T horizontal magnetic field, perpendicular to the loop, fills the top half of the loop. There is no magnetic field through the bottom half of the loop. The loop is released from rest and allowed to fall.
a) Show that the loop reaches a terminal velocity and find a value for the terminal velocity.
b) How long will it take the loop to leave the field? Assume that the time needed to reach the terminal velocity is negligible. How does this compare to the time it would take the loop to fall the same distance in the absence of a field?
terminal velocity equation = sqrt. (4mg/A)
magnetic flux = A B cos(theta)
I = V/R
I'm not sure if I need other equations...
I tried finding the magnetic flux, and I got 0.02 Wb. I know that the initial velocity of the loop is 0 m/s. I am also wondering if there would be some sort of force upward to resist the movement of the loop downward, so that maybe the speed of the loop is slowed somewhat during falling.
Any help would be greatly appreciated, as I am really stuck on how to answer this questions.
Thanks!
Consider the induced EMF in the loop as it cuts through the magnetic field and the resulting current. Then consider that you have a current-carrying wire moving through a magnetic field--what's the force on it?
Terminal velocity will be reached when the net force on the loop is zero.
use
E=B*length*v
then divide E by R to get I
then use
F=B*I*length=mg
solve for speed, then distance/time will give you time needed
for the second part consider the direction of the force applied
esalihm said:
use
E=B*length*v
then use
F=B*I*length=mg
First, I know this is an old thread... But can you expand on this?
How can you solve for E = B*L*v if you don't know v? And then, how could you solve for I?
I think the logic here makes sense to me, but I am not making all the connections.
Nevermind, I see that you are plugging these formulas into each other. Got it!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
