How can we express the Lorentz force law in SI units?
The discussion focuses on expressing the Lorentz force law, specifically the equation F = BIL sinΘ, in SI units. It clarifies that the unit of magnetic field B can be derived as N/C(m/s) or Ns/Cm, leading to the conclusion that the force F also equates to Newtons (N). The relationship between energy in joules and the units of amperes is explored, showing that the units cancel appropriately to confirm the equation's validity. Additionally, the breakdown of joules into mass and velocity units reinforces the consistency of the derived units. Overall, the conversion and relationships among the units affirm the expression of the Lorentz force law in SI units.
divyashree
How do we say that F=BIL SINΘ using the SI units?:confused:
Newton(N)= Weber/m2 * ampere*meter.
please explain as soon as possible.:approve:
Use magnetic lorentz force on a charged particle equation. And you can prove
F=BqvsinΘ.(Magnitude only).
so B= F/qvsinΘ
So, the unit of B is N/C(ms^(-1))
multiply s on both numerator and denominator,
so the unit is Ns/Cm
But F = BILsinΘ (Force on current carrying wire)
Unit of RHS is therefore
=(Ns/Cm)Am
Here A is ampere But A=Cs^(-1)
Substituting, you get the unit as N which is the unit of LHS
A Weber is also energy in joules (stored in field) per ampere. So the amperes and numerator meter cancel and you are left with force (N) = energy (J) / length (m)...which is true since work is force times displacement. You could also break the Joule down into (mass * velocity squared) kg*m^2/s^2. Observe dividing a meter gives you the Newton (mass * acceleration) (kg*m/s^2).
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
