Lorentz velocity transformation problem
An observer on Earth sees spacecraft A moving at 0.50c and spacecraft B at 0.80c. The problem involves calculating the speed of spacecraft A as measured by an observer in spacecraft B using the Lorentz velocity transformation formula. The calculations yield u' = 0.5c, suggesting that spacecraft A is moving away from B at that speed. However, there is confusion regarding the signs used in the calculations, with one source indicating the answer as -0.5c. The discussion highlights the importance of correctly interpreting the reference frames and the signs in relativistic velocity transformations.
Aziza
An observer on Earth observes two spacecraft moving
in the same direction toward the Earth. Spacecraft A appears
to have a speed of 0.50c, and spacecraft B appears
to have a speed of 0.80c. What is the speed of spacecraft
A measured by an observer in spacecraft B?So if S is the reference frame of the Earth, S' is the reference frame of plane B, v is the velocity with which S' approaches S (according to S), u is the velocity with which plane A approaches Earth (according to Earth) and u' is the velocity with which plane A approaches plane B (according to B), then:
v = -0.8c
u = -0.5c
u' = (u-v) / 1-(uv/c2)) = 0.5c
I am interpreting this as meaning that according to plane B, plane A is actually moving away from B at 0.5c. My book, however, has the answer as -0.5c, implying the opposite, i think?...is the book wrong or are my signs wrong? It makes sense to me making v and u negative because the formula for the velocity transformation was derived assuming that S' and the event (plane A here) are moving away from S, not towards...
Hi Aziza! :smile:
I think you're over-thinking this …
… if we ignore relativity, and choose 50mph and 80mph instead,
then obviously B is going faster than A, so A's speed measured by B will be negative :wink:
(of course, this is a non-standard usage of "speed" :redface: … the standard usage is as the magnitude of velocity, so that it's always non-negative)
