Lorentz/velocity transformation
In summary, the speed of ship A as observed from ship B is 0.2728c and the speed of ship B as observed from ship A is 0.9776c. These values are calculated using the formula v'=(v-u)/(1-u*v/c^2) and taking into account the different frames of reference for the observers on Earth and the two spaceships.
GreenLRan
61
Two spaceships approach the Earth from opposite directions. According to an observer on the Earth, ship A is moving at a speed of .753c and ship B at a speed of .851c. What is the speed of ship A as observed from ship B? Of ship B as observed from ship A?
For the speed of ship A with respect to B I tried
(.851c-.753c)/(1-.851c*.753c/c^2) = .2728c
For the speed of ship B with respect to A i tried
(.851c+.753c)/(1+.851c*.753c/c^2) = .9776c
I am not sure of the correct answers, However I'm pretty sure these are wrong. Thanks.
Let [tex] S [/tex] be a coordinate system fixed on the observer on earth, oriented such that the positive x-axis is in the direction of the motion of ship A. Then in that frame ship A has velocity [tex] 0.753c [/tex] and ship B has velocity [tex] -0.851c [/tex].
Now, we set up a fram [tex] S' [/tex] in which ship A is stationary and which has x-axis oriented in the same way as fram [tex] S [/tex]. Then in your formula [tex] v' [/tex] is the velocity of ship B as seen from ship A, [tex] u [/tex] is the velocity of ship A w.r.t. [tex] S [/tex] (earth) and [tex] v [/tex] is the velocity of ship B w.r.t. earth.
Then the velocity of ship B as seen from ship A is
[tex] v' = \frac{-0.851-0.753}{1+0.753\times 0.851} c [/tex]
If you instead consider an observer in ship B then you will get ([tex] v' [/tex] is the velocity of ship A as seen from ship B, [tex] v [/tex] is the velocity of ship A as seen from Earth and [tex] u [/tex] is the velocity of ship B as seen from Earth
[tex] v' = \frac{0.753+0.851}{1+0.753\times 0.851} c [/tex]
and both these are equal to (except for signs) [tex] 0.9776 c [/tex] .
Related to Lorentz/velocity transformation
What is the Lorentz/velocity transformation?
The Lorentz/velocity transformation, also known as the Lorentz transformation, is a mathematical equation that describes how measurements of space and time change for an observer moving at a constant velocity relative to another observer.
Why is the Lorentz/velocity transformation important?
The Lorentz/velocity transformation is important because it forms the basis of Einstein's theory of special relativity, which revolutionized our understanding of space and time. It allows for the prediction and explanation of many phenomena, such as time dilation and length contraction, that were previously unexplainable.
How is the Lorentz/velocity transformation derived?
The Lorentz/velocity transformation is derived from the principles of special relativity, namely the constancy of the speed of light and the relativity of simultaneity. It is a consequence of the fact that the laws of physics must be the same for all observers moving at constant velocities.
What is the difference between the Lorentz/velocity transformation and the Galilean transformation?
The Lorentz/velocity transformation takes into account the effects of special relativity, such as time dilation and length contraction, while the Galilean transformation does not. The Galilean transformation is only applicable for objects moving at speeds much lower than the speed of light, while the Lorentz transformation is applicable for all velocities.
Can the Lorentz/velocity transformation be applied to objects with mass?
Yes, the Lorentz/velocity transformation can be applied to objects with mass. In fact, it is necessary to take into account the effects of special relativity when dealing with moving objects with mass. This is because the mass of an object increases as its velocity approaches the speed of light, which affects the measurements of space and time for that object.
