Loudspeaker Question (Sound and Intensity)
The discussion focuses on calculating sound intensity and amplitude ratios from a spherical loudspeaker emitting 10 W in an anechoic chamber. The intensity at a distance of 3.0 m is calculated to be 0.0884 W/m², while at 4.0 m, it is 0.0497 W/m². The amplitude at 3.0 m is 0.297 m, and at 4.0 m, it is 0.223 m, leading to a ratio of approximately 0.751. Participants clarify that while intensity is proportional to the amplitude squared, the problem primarily requires calculating surface areas for intensity. The correct approach emphasizes the use of power and surface area rather than amplitude relationships.
K_Physics
Suppose a spherical loudspeaker emits sound isotropically at 10 W into a room with completely absorbent walls, floor, and ceiling (an anechoic chamber). (a) What is the intensity of the sound at distance d = 3.0 m from the center of the source? (b) What is the ratio of the wave amplitude at d = 4.0 m to that at d = 3.0 m?
[/B]
I = P/A
I ∝ A^2 (According to my TA)
[/B]
Part A:
I = P/A
I = 10/4π(3.0)^2 = 0.0884 W/m^2
Part B:
According to my TA, Intensity is proportional to the amplitude squared. I was wondering if I could use this relationship to answer part B.
Intensity at 3.0 m = 0.0884 W/m^2
Amplitude at 3.0 m = 0.297 m
Intensity at 4.0 m = 0.0497 W/m^2
Amplitude at 4.0 m = 0.223 m
Ratio: 0.223/0.297 = 0.751
Not sure if this is the correct approach or if the relationship I ∝ A^2 is correct or not.
[/B]
I = P/A
[/B]
Part A:
I = P/A
Part B:
You are already given the power, so you only need to figure out what the surface areas are at the different radii to get the Intensity in W/m^2.
Intensity may be proportional to the amplitude of the sound pressure wave squared, but you don't need that in this problem.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
