Lumped Parameter Method: Analysis & Benefits
  • Thread starter Thread starter Baltistani
    Method
The lumped parameter method is a simplified approach in finite element analysis that assigns constant parameters to stepwise regions, allowing for easier computation of a structure's response. Instead of solving complex differential equations, this method uses influence coefficients to assess how different sections interact. It is applicable in various fields, including heat transfer and fluid flow analysis, as demonstrated by tools like SINDA/FLUINT, which is widely used in industries such as aerospace and automotive. This method can also linearize non-linear problems and is analogous to equivalent circuits in electronics. Overall, the lumped parameter method streamlines the analysis of complex systems by reducing spatial dependencies.
Baltistani
what is lumped parameter method for analysis
It is a type of finite element analysis.
Instead of performing the differential equations to determine the response of a structure, you assign stepwise regions where the parameters are constant (EI, GJ, mass per length, etc.) and use influence coefficients to determine how each section affects the other sections.
Lumped parameter methods can be applied to finite difference as well, e.g.
http://www.crtech.com/sinda.html
Heat Transfer and Fluid Flow Design and Analysis Software
SINDA/FLUINT is a comprehensive finite-difference, lumped parameter (circuit or network analogy) tool for heat transfer design analysis and fluid flow analysis in complex systems. It is used at over 500 sites in the aerospace, electronics, petrochemical, biomedical, and automotive industries, and in over 25 countries.
Basically as enigma indicated, it is a method to simplify the solution to a rather complex system.
For example, one would model an entire nuclear reactor based on the thermal energy generated by the entire core, say 3500 MW. However in the reator, there are 193 assemblies in which power generation is spatially dependent. A lumped parameter model would ignore the spatial dependence. Within the core, one simply uses an average (or global heat transfer coefficient).
This approach can be used to linearize a non-linear problem.
In electronics, the use of equivalent circuits would be considered a lumped parameter model - http://hyperphysics.phy-astr.gsu.edu/hbase/electric/thevenin.html, or http://hyperphysics.phy-astr.gsu.edu/hbase/electric/norton.html#c1.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
