M,N is subset of Hilbert space, show M+N is closed
The discussion centers on proving that the sum of two closed linear subspaces, M and N, of a Hilbert space is also closed, given that the inner product (u,v)=0 for all u in M and v in N. The participants highlight that if N is finite-dimensional, M+N is closed; however, if N is infinite-dimensional, additional considerations are necessary. The proof involves demonstrating that a Cauchy sequence in M+N converges to a limit within M+N, utilizing orthogonal projections and the definitions of closed sets and completeness in Hilbert spaces.
  • Understanding of Hilbert spaces and their properties
  • Familiarity with inner product spaces and orthogonality
  • Knowledge of Cauchy sequences and their convergence
  • Concept of closed sets and completeness in metric spaces
  • Study the proof of the theorem stating that a linear subspace of a Hilbert space is closed if and only if it is complete
  • Explore the implications of finite vs. infinite dimensionality in Hilbert spaces
  • Learn about orthogonal projections in the context of Hilbert spaces
  • Investigate the properties of Cauchy sequences in relation to convergence in metric spaces
Mathematicians, students of functional analysis, and anyone studying the properties of Hilbert spaces and linear algebra.
Fellowroot
[/B]
Let M, N be a subset of a Hilbert space and be two closed linear subspaces. Assume that (u,v)=0, for all u in M and v in N. Prove that M+N is closed.
I believe that (u,v)=0 is an inner product space
This is a problem from Haim Brezis's functional analysis book. It seems to be closely related to a typical linear algebra problem but only with Hilbert spaces.
The best thing I could find on this was this, but I need a little help showing this.
[edit]
I came across some new info. It has to do with whether N is finite dimensional or not. If N is finite dimensional then yes, M+N can be closed, but it may not be closed if N is infinite dimensional. Apparently I'm supposed to show this with induction on the dimension of N. Can anyone help on this part.
You have to show that a Cauchy Sequence in M + N splits into two Cauchy sequences in M and N. Their limits add to the limit in M + N. Use the definition (of the norm) and the orthogonality. The dimensions shouldn't play a role.
^ I don't think using cauchy sequences does the job here. my teacher said I want to show closed. i don't see how cauchy shows how these spaces are closed.
Closed has been defined as converging Cauchy sequences by the OP, i.e. one has to show that a Cauchy sequence in M+N has a limit in M+N. It is straight forward.
Oh yeah, apparently you use orthogonal projections.
Your book's definitions are a bit unusual. These are the definitions I'm familiar with: A subset M (of a metric space X) is said to be closed if the limit of every convergent sequence in M is in M. (Convergence with respect to the metric of X doesn't imply that the limit is in M). A metric space M is said to be complete if every Cauchy sequence in M is convergent. (Convergence with respect to the metric of M does imply that the limit is in M).
The following theorem is easy to prove: A linear subspace of a Hilbert space is closed if and only if it's complete.
If you prove that theorem first, you will only need to prove that M+N is closed in the sense defined here. Let ##(x_n)_{n=1}^\infty## be a convergent sequence in M+N. Denote its limit by x. Now prove that x is in M+N, and you're done.
  • · Replies 43 ·
