Maclaurin Series, expressing 2^x as a M series.
Disowned
Okay I was given this problem as a challenge question. It simply says expressing 2x power as a Maclaurin Series. At first, following an example given by my instructor, I thought that by examining the function as I took multiple derivatives I could find a pattern.
By as you can imagine taking multiple derivatives of an exponential function is anything but pretty. So instead I thought to express the function as a logarithm and set 2x = n, from there I could rewrite it as Log2 n = x. But I'm having trouble visualizing that as a sum at 0 to infinity. Anyone got any hints?
Well, taking higher derivatives of a^x isn't all that awful... but there is a short cut.
Write 2 as e^{ln 2}. Then our function becomes
y = 2^x = (e^{ln 2})^x = e^{(ln 2) \cdot x}
using properties of exponents. (This is a fairly standard "trick".)
Now call u = (ln 2) · x and use it in the Maclaurin series for e^u.
Likes weezy
THAT. IS. BRILLIANT! Thank you, I can use this info.
Yes... yes, it is rather... not that I invented the idea...
The same trick is used to obtain the rule for differentiating exponential functions:
\frac{d}{dx} a^x = \frac{d}{dx} (e^{ln a})^x = \frac{d}{dx} e^{(ln a) \cdot x}<br /> = (ln a) \cdot e^{(ln a) \cdot x} [by the Chain Rule]
= (ln a) \cdot a^x
(a useful differentiation rule to remember; you can see immediately that it gives \frac{d}{dx}e^x = e^x as expected)
So, by extension, we have for f(x) = a^x ,
\frac{d^n}{dx^n} a^x = (ln a)^n \cdot a^x
which would also give you the Maclaurin series you were after.
Likes weezy
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
