Magnesium and acid rates reactions
The discussion focuses on conducting an investigation into the reaction between magnesium and various acids, emphasizing the need for suitable apparatus to ensure accurate and reliable results. Key considerations include safely heating acids, collecting gas products, timing the reactions, and recording volumes. One suggested method involves measuring the time taken to produce a specific amount of hydrogen gas from the reaction of magnesium with hydrochloric acid. Participants discuss the importance of examining variables such as surface area, pH, and concentration. Concerns arise regarding the use of an inverted burette for collecting hydrogen gas, particularly about potential inaccuracies due to hydrogen's interaction with water. However, reassurance is provided that accurate readings can still be obtained.
kjwale
[SOLVED] magnesium and acid rates reactions
im producing an investigation in the reaction between magnesium a solid metal, and acids of varying concentration, pH and temperatures. these variables are to produce results for comparison. however i am unsure about what apparatus would be most suitable, for this investigation eg heating acids safely, collecting gas products, timing them, volumes to be recorded.
one approach is to record the time taken for a certain amount of H2 gas to be produced in a reaction between Mg and HCl.
what would you suggest? any offers welcome.
Chemistry news on Phys.org
I suggest you examine the effect of surface area as well as pH and concentration.
chemistree
thanks for the suggestions, i have already thought of these as investigations my question is what apparatus should i use to produce results usefull for comparison ie with a good degree of accuracy and minimal possible error.
perhaps someone can suggest such experiments and ideal apparatus?
Have you heard of gas burets? Try this.
ive heard of them, but i don't believe our chemistry budgit at college stretchs that far, I've been looking at measuring gas evolution using an inverted burette and a trough full of water etc but my worry is that I've used it before only to collect oxygen. here i will be collecting hydrogen and I am worried as an amatuer chemist whether i will get accurate readings as i can't think for the life of me wether hydrogen gas will react with the water giving inaccurate results.
You will be fine. Read the article more carefully.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
