Magnet and Current-carrying wire/circuit
  • Thread starter Thread starter zebra1707
    Magnet
The discussion focuses on the application of the Right Hand Rule and Fleming's Left Hand Rule to predict the movement of a current-carrying wire in a magnetic field. Participants clarify that the Right Hand Rule applies to generators, while Fleming's Left Hand Rule is used to determine the direction of force on the wire. The consensus is that the wire will move away from the magnet due to a northward force, and that in the absence of a magnet, two parallel wires do not exert force on each other.
  • Understanding of electromagnetic principles
  • Familiarity with Fleming's Left Hand Rule
  • Knowledge of the Right Hand Rule
  • Basic concepts of current flow in circuits
  • Study the applications of Fleming's Left Hand Rule in electric motors
  • Explore the Right Hand Rule in the context of electromagnetic induction
  • Research the effects of magnetic fields on current-carrying conductors
  • Investigate the forces between parallel current-carrying wires
Students of physics, electrical engineers, and anyone interested in understanding the principles of electromagnetism and their applications in circuits and motors.
zebra1707
Hi all Can you assist - I think that I am on the right track - but then I could be wrong..
View attachment Physics Question 1.doc
Predict which direction the wire will move
Right hand rule
Current flows from positive to negative. Right hand rule has magnetic field - anticlockwise.
A northward force. The assumption is that the wire will move away from the magnet.
Two other related questions...
2. Would the wire returning from the resistor to the source be affected in the same direction and or as strongly. Explain?
I assume a southward field and therefore will be attracted to the magnet.
3. In the absence of the magnet, would the two long wires exert any force on each other? Explain.
No, force.
Cheers Petra
zebra1707 said:
Right hand rule
To work out the direction the wire will move you will need to use Flemings left hand rule, the right hand rule is for generators =]
HI Rory
Thanks for the reply. The question states (Remember the righthand rule).
Cheers Petra
