B Magnetic bottle is said to store hydrogen (and then convert into helium?)
  • B
  • Thread starter Thread starter Doriangrey
The magnetic bottle is a device used in fusion research to confine plasma at extremely high temperatures, around 100 million degrees Kelvin, allowing for the storage of charged particles, or ions. While hydrogen can be stored in physical bottles at normal temperatures, these cannot hold plasma, which is why magnetic bottles are utilized despite their inefficiency due to significant leakage. The fusion process typically involves isotopes of hydrogen, such as deuterium and tritium, which combine to form helium. Helium-4 is primarily produced through the fusion of deuterium with itself or with tritium, while helium-3 can result from the decay of tritium. Overall, magnetic bottles serve as a practical, albeit imperfect, solution for plasma storage in fusion applications.
Doriangrey
TL;DR Summary
Magnetic bottle is said to store hydrogen and then convert into helium.
How exactly does it store hydrogen and how can hydrogen be converted to helium? Is it the complete valency of hydrogen that gives helium?
They say that no other devices can store hydrogen, so how exactly is the magnetic bottle able to do so? More importantly how does it convert it into helium?
The application you are referring to is fusion. Magnetic fields are used to confine a plasma which has a temperature of around 100 million degrees Kelvin.
Hydrogen at normal temperatures (and pressures) can be stored in physical bottles.
Likes russ_watters, Vanadium 50, Doriangrey and 1 other person
Oh, so hydrogen fuses with another hydrogen to become stable and get the configuration of helium or is there another mechanism?
There are a number of nuclear reactions that involve different intermediaries (see Han Bethe Nobel Prize) but they are similar.
A magnetic bottle can be used to store charged particles, called ions, usually in the form of a plasma. But it is actually a very poor method of storing anything, even plasma, as leakage through the ends is fairly significant. It's just one of the easiest methods of storing plasma for research, as better storage methods are vastly more complicated and expensive.
Hydrogen is fused with itself to make helium, but we are usually talking about fusing dueterium and tritium, which are isotopes of hydrogen. That is, regular, plain, basic hydrogen is just a single proton with a single electron. Dueterium is a proton bonded to a neutron and tritium is a proton bonded to two neutrons. All three have a single electron and a single proton, making them chemically identical except for differences in mass. Plain hydrogen and dueterium are both entirely stable. Tritium is unstable and will undergo beta decay with a half-life of about 12 years.
Helium can be formed from the fusion of deuterium with itself or with tritium. Specifically helium-4, the most common isotope of helium. Another isotope of helium, helium-3, is created when tritium naturally decays. Both helium-3 and helium-4 are chemically identical, differing only by mass.
Just about any compressed gas cylinder can store hydrogen in gaseous form, though there will always be some leakage due to hydrogen's very small size. However these cylinders cannot store plasma. You need magnetic bottles or another magnetic-based storage device to handle plasma.
Thanks a lot for clearing this up!
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
