Magnetic Field and spring constant
An unknown mass M has a period of oscillation of 1.0 second with a spring of unknown spring constant k. Adding 200g to the mass increases the period by 0.6 seconds. The discussion focuses on determining the values of the unknown mass M, the spring constant k, and the mass required for a 2-second oscillation period. The calculations involve using the formulas for oscillation periods and spring constants. Participants emphasize the importance of showing work for accurate assistance in solving these physics problems.
rinspd
An unknown mass M is found to have a period of oscillation of 1.0 second using a spring of unknown spring constant k. When an additional 200g is added to the initial mass, the period of oscillation increases by 0.6 seconds Determine: (a) The unknown mass M (g), (b) The spring constant k (N/m), and (c) the mass corresponding to an oscillation period of 2 seconds for this spring.
Please check your PMs. You *must* show your efforts before we can offer tutorial help on your schoolwork.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
