Magnetic field at the center of a loop
The problem involves calculating the magnetic field at the center of a circular loop of wire with a radius of 14.4 cm, carrying a current of 1.60 A. The context includes the application of the Biot-Savart law and considerations for contributions from both the loop and straight sections of the wire.
  • Participants discuss the use of the Biot-Savart law to determine the magnetic field from the loop and question whether to include contributions from the straight sections of the wire through superposition.
Some participants have provided guidance on the need for superposition and the appropriate equations to use. There is an ongoing exploration of the calculations involved, with some confusion regarding the application of formulas and the integration process.
Participants express uncertainty about the calculations for the magnetic field from both the loop and the straight wire, with specific attention to the accuracy of their results and the assumptions made in their approach.
Nicki
A conductor consists of a circular loop of radius
R = 14.4 cm
and two long, straight sections as shown in the figure. The wire lies in the plane of the paper and carries a current
I = 1.60 A.
Find the magnetic field at the center of the loop.
biot-savart law
I know I need use biot-savart law to get the field created by the loop, which is giving me 8.77 uT. This is apparently within 10% of the correct answer.
Do i need to find the current from the straight part of the wire too (superposition)?
I'm just not sure how to do this / what equations to use to do this?
R = 14.4 cm
I = 1.60 A.
biot-savart law
Yes. And superpostiion is an excellent idea.
You should have an expression for the magnetic field at a given distance from a current-carrying wire...
thats where I'm confused.
shouldn't i use B = (uI)/(2 pi r) ?
4pi x 10^-7 x 1.6A / 2 pi x .144m ? this gives me 2.22 uT which when added to the 8.77 is out the the correct range
2.22 μT looks right for the straight wire. But the loop contribution looks a bit high to me. Can you show the details of your work there?
i need to take this integral of this don't i?
No, the expression gives the field magnitude, not a differential element. The integration was already done in deriving the expression.
Ahhhh thank you! my mistake was in the calculation for the loop! i left the 4pi in place when using u/4pi
hahaah that was dumb. but thank you, i got the right answer. it's 9.20 uT!
9K
  • · Replies 17 ·
