How Does Current Distribution Affect Magnetic Fields?
The discussion focuses on calculating the current in a second wire and the magnetic field at the center of a long metal cylinder carrying a current. The magnetic field from the wire is derived using Ampere's Law, resulting in the conclusion that the current in the second wire must be negative half of the cylinder's current to achieve a zero magnetic field at point P. The magnetic field at the center of the cylinder is determined to be zero due to symmetry, with the field solely contributed by the wire located at a distance of 3R. The final magnetic field calculation yields a value of B = μI_C/(12πR). Overall, the calculations and reasoning presented are confirmed to be correct.
CAF123
A long metal cylinder of radius R is carrying a current ##I_C## into the page and the current in a second wire a distance 2R from the cylinder is set so that the magnetic field at point P is zero.
Calculate:
1. the current in the second wire,
2. the magnetic field at the centre of the cylinder.
Assume that the current is evenly distributed across the shaded area of the cylinder.
(see picture below)
Ampere's Law
Biot-Savart
The B field from the wire is ##B = \frac{\mu I}{2 \pi R}##. Apply Ampere's Law to find the B field outside the cylinder:
So, ##\oint B \cdot ds = \mu I_C \Rightarrow B = \frac{\mu I_C}{2 \pi (2R)}##. I took a circular loop to be at a radius bigger than than that of the cylinder and I think B and ds would be parallel. Since P is at a distance 2R away, this gives the above.
Add the two results together: $$\frac{\mu I}{2 \pi R} + \frac{\mu I_C}{4 \pi R} = \frac{2 \mu I + \mu I_C}{4 \pi R} = 0 \Rightarrow I = -I_C/2.$$The -ve indicating the direction of I opposite to that of ##I_C##.
For the B field at the centre, I just said that since the problem is symmetrical the B field would be zero from the contributions of the current around the cylinder. So the B field is solely due to the current in the wire a distance 3R away. This means B is ##B = \frac{\mu I_C}{12\pi R}##.
Can someone tell me if I did it correct? If so, I have some further questions about Ampere's Law.
Everything looks good.
