Magnetic field due at a point due to a wire outlining an ellipse
The discussion focuses on calculating the magnetic field at a point due to a wire segment outlining an ellipse using the Biot-Savart Law. The initial approach considers a circular wire where the angle between the differential element and the radial vector is constant, simplifying the integration process. However, for an elliptical wire, both the angle and distance from the point of interest vary, complicating the integral. A suggested method involves using the parametric equations of the ellipse in the integral, leading to a complex expression that requires careful evaluation. The challenge lies in integrating the resulting expression, which is noted to be quite complicated.
Duderonimous
Find the magnetic field due to a curved wire segment.
Biot-Savart Law (differential form)
dB=\frac{\mu_{o}i}{4\pi} \frac{d\vec{S}\times \hat{r}}{r^{2}}
In class we found the magnetic field at a point in space (point P) caused by the current running through a wire. Point P is equidistant from every point on the wire call this distance R. dS is a differential element that points along the wire and r hat points toward point P. The angle between dS and r hat is 90 degrees at all points.
The point P is essentially the center of a circle and the wire outlines the edge of a circle.
B=\frac{\mu_{o}i}{4\pi}∫\frac{d\vec{S}\times \hat{r}}{r^{2}}
B=\frac{\mu_{o}i}{4\pi}∫\frac{|d\vec{S}||\hat{r}|sinθ}{r^{2}}
B=\frac{\mu_{o}i}{4\pi R^{2}}∫dS(1)sin90^{o}
B=\frac{\mu_{o}i S}{4\pi R^{2}} S=Rθ_{1}
where θ_{1} is the angle swept out between one end of the wire and point P and the other end the wire and point P.
B=\frac{\mu_{o}i R θ_{1} }{4\pi R^{2}}
B=\frac{\mu_{o}i θ_{1} }{4\pi R}
OK punchline.
I was thinking how could I find the magnetic field at point P due to a piece of wire that outlines a portion of an ellipse. This would mean that the angle between dS and r hat would be a different angle at every point on the wire and the distance between point P and the wire would be different at every point along the wire.
So the integral would be
B=\frac{\mu_{o}i}{4\pi}∫\frac{dS sinθ}{r^{2}} where S,θ, and r are all variables. How would I integrate this?
dS=drdθ where dθ the angle between dS and r hat and dr is the infinitesimal change of the radius as the integral adds from one end of the wire to the other end.
B=\frac{\mu_{o}i}{4\pi}∫\frac{drdθ sinθ}{r^{2}}
This is as far as I can get. Any help would be appreciated. Thanks.
In retrospect maybe I shouldn't say the wire outlines an ellipse. I just want a wire the satisfies the conditions that the angle between dS and r hat changes at every point along the wire and the distance between point P and the wire changes at every point along the wire. Thanks again.
Are you thinking the wire is a portion of the ellipse or the whole thing? I got the impression you were talking about a piece of wire that was just curved, but if it is a whole ellipse then the field will be zero t the center just like a circle.
Were I doing it I would use the equation for an ellipse in the integral and go from there.
An ellipse is
r(\theta) = \frac{ab}{\sqrt{(b^2\cos^2\theta)+(a^2\sin^2(\theta)}}
so plugging into B-S law:
$$B = \frac{\mu_0I}{4\pi} \int \frac{r (b^2\cos^2\theta)+(a^2\sin^2\theta)d\theta}{(ab)^2}= \frac{\mu_0I}{4\pi (ab)}\int \sqrt{(b^2\cos^2\theta)+(a^2\sin^2 \theta)} d\theta$$
which is a very ugly looking integral.
Likes 1 person
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
