Magnetic field in frame of moving charge
A moving charge generates a magnetic field around it, which varies at fixed points as the charge passes by. The magnetic field is influenced by the current produced by multiple moving charges in a conductor, rather than being solely dependent on a single charge. When an observer moves with the charge, they would not experience a magnetic field at the instant they coincide with a stationary observer, who would measure both electric and magnetic fields. The electric and magnetic fields are not invariant under changes in inertial frames, meaning they change based on the observer's motion. Ultimately, the interaction between electric and magnetic fields is governed by Maxwell's equations and the Lienard-Wiechert potentials.
Dexter Neutron
A charge moving relative to some observer produces magnetic field in space around it. Now I want to ask that how does the magnetic field of the charge at any fixed point varies as the charge passes by. Or is the B field only dependent on current and not a single moving charge?
If I introduce one more observer to be moving with the charge then if a time comes at which both the observer coincide, then at that instant will magnetic field be experienced by only stationary observer or both?
A single moving charge does produce a current. The B field of the current in a conductor is the sum of the B fields of all of the charges moving in the conductor.
The electromagnetic field satisfies Maxwell's equations. The solution for a single moving charge can be found, for example, here (slide 8): https://www.physics.rutgers.edu/ugrad/227/L15 Magnetic Field of Currents Biot-Savart.pdf
This question does not make any sense. If an observer is not moving with respect to the charge, then they will either coincide at all times or at no time.
For an observer at rest with respect to the charge, there would be no magnetic field. The electric and magnetic field are not invariant under boosts (changes in inertial frames with a relative velocity), i.e., if you change to a moving frame, the electric and magnetic fields will change.
The fields for a classical point charge are given by the Lienard Wiechert potentials: https://en.wikipedia.org/wiki/Liénard–Wiechert_potential
In the appropriate limits these fields reduce to Coulomb's law and the Biot Savart law but you can use them for any arbitrary motion.
I think the question is about when the moving observer coincides with the stationary observer. The stationary observer would measure a magnetic field with her compass (and there would be some electric field as well) but the observer moving with the charge would measure only an electric field.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
