Magnetic field of 2 infinite wires.
The discussion focuses on calculating the magnetic field strength generated by two infinite wires carrying equal and opposite currents located at y = -a and y = a. Using Ampere's law, the magnetic field from one wire is expressed as B(y) = μ₀I/(2πr₁), with r₁ being the distance from the wire, which is determined to be a - y. The contributor finds that the magnetic fields from both wires cancel each other out, resulting in a net field strength of zero. They express frustration over this outcome and question their calculations, particularly regarding the distances used for the field strength equations. The discussion highlights the challenges in understanding magnetic field interactions between parallel wires.
dikmikkel
Two thin, long wires situated in y = -a and y = a carrying two equal in magnitude and opposite running currents I.
Find the field strength in therms of y.
Find the average Field strength in a region -b to b, where 0 is between the 2 points.
Amperes law.
I find via. Amperes' law, that the field of the wire in -a (current running down) has the magnitude:
B(y) = \dfrac{\mu_0 I}{2\pi r_1}
Where r1 is the distance from the wire, now i find that r1 = a-y.
The field from the other is the same with the distance r2 instead of r1. r2 = a-y too so the field is zero and the average is of course also 0, and that is annoying. What have i done wrong.
Better check if, for the downgoing wire, r1 = a - y.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
