Magnetic field of cylindrical magnet
The discussion focuses on calculating the magnetic field of a cylindrical magnet positioned at a point P in cylindrical coordinates. The user seeks a general analytical model for a magnet with specific dimensions and remanent flux density, expressing frustration over the complexity of existing papers and the lack of clear assumptions in simpler models. It is noted that while finite element methods like COMSOL can simplify the process, the user is looking for a more straightforward analytical solution. The conversation highlights the challenges in deriving magnetic field solutions due to the complexities of differential equations and boundary conditions. Overall, the quest for a simple yet general analytical solution remains unresolved.
sgsawant
Hi,
I wanted to calculate the magnetic field of a cylindrical magnet at a point P (r,ɵ,z). The magnet can be at the origin or anywhere convenient. Preferably the axis of the magnet is aligned with the z axis.
The magnet is of radius r_m and height h_m. The remanent flux density of the magnet is B_r. I have seen a few papers, but some of them are too complex. The simple solutions too, involve models which have unclear assumptions.
If you know a good analytical model, please point me in the right direction. I know that using FEM (say COMSOL) it is really easy.
Regards,
-sgsawant
http://faculty.uml.edu/cbaird/all_homework_solutions/Jackson_5_19.pdf"
Thanks! But that's a very specific case - I am necessarily looking for a general case solution.
I appreciate your effort though.
It's just that there is no simple solution, analytical and general.
As you may often expect when a field defined by a differential equation has edgy boundaries.
And as you may expect about every time with the magnetic field, because it makes no huge difference between conductors and isolators.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
