aokidopi
- 29
http://s3.amazonaws.com/answer-board-image/2924bffb-da01-4543-9697-b67da02e5a5a.jpeg
The picture above shows four square regions. Each of the four regions may have its own uniform magnetic field. If there is a uniform magnetic field in a region, the field is directed either into or out of the screen (or the page, if you printed your assignment out on paper). Two charged particles pass through this region. Particle 1 has a positive charge. The path of particle 1 is a quarter-circle in region A, a half-circle in region D, another quarter-circle in region A, and a quarter-circle in region B. The path of particle 2 is a straight line in region C, and a quarter circle in region D.
Particle 1 has a charge of +50.0 microcoulombs, and a mass of 1.20 milligrams. Particle 1 also has a speed, when it enters region A, of 5.00 m/s.
(d) If region A is a square measuring 90.0 cm on each side (the other regions have the same size as region A, of course), what is the magnitude of the magnetic field in region A?
T
(e) From the instant particle 1 enters region A for the first time, until it leaves region B, how much time elapses?
s
(f) If particle 2 has the same mass and the same speed as particle 1, what is the charge on particle 2?
microcoulombs
T
s
microcoulombs
