How Does Magnetic Flux and Peak EMF Relate in a Solenoid-Coil System?
champ0342
A coil is located at the center of a long solenoid of radius R = 15cm which has 5x10^7 turns per meter and carries a current I = 16A. The coil is coaxial with the solenoid and consists of 5 turns of wire each in the shape of a square of length a = 5cm on each side.What is the magnetic flux passing through each loop of the coil? If the current in the solenoid is not constan but varies as I=Im cos wt, where I am = 16A and w = 10rad/sec, find the peak emf induced in the coil.
I would like to offer relevant equations but I don't think I have any. I have tried the equations I thought were relevant without coming up with the correct equation
flux = NiA -> 16*.05*5=4 but the correct answer is 2.5. I haven't even got a clue about peak emf...
Magnetic field B at the center of a long solenoid is mu_0*n*I, where mu_0 = 4*pi*10^-7. And flux = B*A
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
