Magnetic flux density
  • Thread starter unseensoul
unseensoul
47
magnetic flux density is denoted by the B symbol
magnetic flux is denoted by the [tex]\phi[/tex] symbol
so why do people use B as if they were referencing to magnetic flux?
"magnetic flux density is a measurable quantity indicating the strength of a field" ...this was stated by a teacher of mine...anyway, is true?
First, magnetic flux density isn't it the same as magnetic induction, i.e. magnetic flux per unit area perpendicular to the magnetic field?
Second, I thought that the strength of a field was denoted by H...
I've been searching throughout the internet and I found different meanings for the same thing which lead me to get more confused.
Best regards
-unseensoul
Answers and Replies
TVP45
1,044
Here's a good start
http://hyperphysics.phy-astr.gsu.edu/Hbase/hframe.html
Just remember that, at a practical level, the magnetic field strength H is most useful when dealing with magnetic materials (soft iron, silicon steel, etc.).
If you just want a memory trick (not completely true), think of H as the cause and B as the result.
I'm sorry to give a 75% answer (i.e., not absolutely true), but I can't think of anyway short of about three hours to say it all. Perhaps another responder will have a more succinct answer.
unseensoul
47
I've taken a look to it before I came here and it didn't help me :\
Thank you for your reply
ps: I'm sorry to get you back so late...
dst
379
B is magnetic flux density - keyword: density. As in, magnetic flux per unit area/volume. Phi is the total amount, i.e. in the same way that density * volume = mass.
Referring it to as magnetic flux is probably just a short hand way of going about things.
unseensoul
47
I didn't mean that. What I'd like to know is why is the magnetic flux density referred as the magnetic field strength?
Thank you
TVP45
1,044
Magnetic field strength is not the same as the magnetic flux density. They are proportional (the constant (?) of proportionality being permeability). If some source refers to them as the same, that source is incorrect.
pam
458
The words describing magnetism can be ambiguous and vary over time.
It is best to use B and H instead of words, because the usages B and H are universal.
Suggested for: Magnetic flux density
  • Last Post
