Magnetic force created by one wire over another
The problem involves two parallel wires with a specified weight per unit length, seeking to determine the necessary current in each wire for the magnetic field produced by one wire to balance the weight of the other. The context is rooted in electromagnetism and the forces between current-carrying conductors.
  • Participants discuss the application of relevant equations and the setup of the problem, including considerations of equilibrium and the relationship between current and magnetic force. There is an attempt to derive the current needed based on the given weight and magnetic field equations.
The discussion includes attempts to calculate the current required, with some participants providing numerical values and questioning the correctness of their calculations. There is a recognition of potential errors in the calculations, but no consensus on the final answer has been reached.
Participants note the lack of specific length information and the need to work per unit length. There is also mention of the direction of currents and how it affects the interaction between the wires.
Parad0x88
Two wires, each having a weight per unit length of 10–4 N/m, are strung parallel, one 0.3 m above the other. If the wires carry the current of same magnitude, how great must the current in each wire be for the magnetic field due to the lower conductor to balance the weight of the upper conductor? What have to be the directions of the two currents for that to work?
Since we are not given any length, we must work per unit of length, in this case meters.
Weight = mass X gravitational acceleration.
Since we are already given the weight, we simply must find the equivalent force to create an equilibrium.
We also know I1 = I2
F1 = (μ0I1I2)/(2pi X a)
Simply solve for I, since I1 = I2, we can re-write:
10-4 N = (μ0I2)/(2pi X a)
OK, so far, so good. So what's the answer?
Oh well I had assumed if the formula was good I wouldn't have to go all the way here, but here goes:
(4pi X 10-7 X I2) / (2pi X 0.3)
FB = (2 X 10-7 X I2) / .3
FB = 6.667 X 10-6 X I2
I2 = 10-4 / 6.667 X 10-6
I2 = 15
I = 3.87
As for the direction, let's see if I can figure this out, and use what you have taught me in the previous problem :D.
We want them to repel each other. If both wires have the same current direction, they would attract each other, therefore one has to flow left to right, and the other right to left
You lost a factor of 10 halfway. Otherwise good.
Awesome, thanks! And yeah you're right, should be 6.667 X 10-7
  • · Replies 23 ·
10K
