Magnetic Force on a Particle at Zero Velocity
The discussion centers on calculating the magnetic force on an electron as it transitions from a velocity to zero in a magnetic field. Initially, the magnetic force was calculated using the cross product of velocity and magnetic field, resulting in a force of 6.246e-14 N. However, confusion arises when determining the magnetic force at the moment the electron's velocity reaches zero, leading to the realization that the magnetic force is zero when the velocity is zero. Participants emphasize the importance of understanding the Lorentz force, which combines both electric and magnetic forces, and clarify that without velocity, there can be no magnetic force acting on the particle. Ultimately, the conclusion is that the magnetic force is zero at the moment the electron's velocity becomes zero.
RunsWithKnives
ok I'm stuck here...
At a particular point in time, an electron is moving with a velocity of
v=(2.0*10^6 m/s)i + (3.0*10^6 m/s)j
in a constant magnetic field with strength
e=(0.030T)i - (0.15T)j
What is the magnitude of the magnetic force on the electron at that moment? this i found by taking the cross product and multiplying by charge of an electron 6.246e-14N
The electron moves into an area where an electric field is used to bring its velocity to zero in 4.5 X 10-2 seconds. At the moment when the velocity of the particle is zero, what is the magnitude of the magnetic force on the particle?
this is where I'm stuck... i thought that vf = vi + at would give me the acceleration which I could then multiply by the mass of an electron (F=ma)... which would give me F... I know I'm probably missing something elementary here
so I got the magnitude of acceleration by taking the squares of both components of velocity and than the square root... as in sqrt(i^2 + j^2) = v
which gave me 1.3e13 m/s
so then I got 0 m/s = 1.3e13 m/s + a (4.5e-2 s)
a=-2.888e14 m/s^2
F= (9.110e-31 kg)*(2.888e14 m/s^2)
F=2.632e-16 N
so what am i missing?? thanks
Haven't read it all but I think you forgot to take the square root here...so really,
|v| = 3.6 e6 m/s
|v| = 3.6 e6 m/s
stupid mistake ... changes my answer to 7.299e-23 N... which still isn't right... any other ideas ?? :confused:
edit: I'm guessing that I'm missing something obvious... I'm supposed to do this using vectors since F = q VxB ... right?? this was how I did the first part... I'll try again in the morning.. too tired to think :zzz:
Either you've not copied the question down correctly, OR there are more sub-questions following this OR it's a trick question. :wink:
Look at it again : "What is the magnetic force when the velocity is zero ?" :smile:
Hi
Does the region where the electric field declerates the particle, also include the magnetic field? Otherwise, the magnetic force + direction at the point of entry into this new region can be computed using the Lorentz force definition. The electric field must have a magnitude and direction so as to bring down the velocity to zero.
Now at the point the velocity becomes zero, the acceleration is nonzero. But now your answer depends on whether B is operating in that region or not. If it is not operating, then qv(cross)B is the magnetic force and it is zero irrespective of whether v is zero or not. Note that the total force is always qv(cross)B + qE where E is the electric field (the trivial case is that one of the fields is zero, when the Lorentz force reduces to either the magnetic force expression or the electric force one).
Cheers
Vivek
it was a trick question... I am soo angry right now... there is no magnetic force unless the particle has a velocity... AHHHHHHHHHHHHHHHHHHH :cry:
the answer is zero!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
