Magnification through a lens at various diameters
  • Thread starter Thread starter Ken Van Cleave
    Lens Magnification
Magnification through a lens varies significantly with target size, even when lens power remains constant. The observed ratio between the original target diameter and the viewed diameter changes notably for larger targets, complicating accurate calculations of focal length and lens power. This discrepancy is attributed to radial distortion, which affects how different target sizes are perceived through the lens. Understanding the impact of target size on magnification is crucial for precise optical measurements. Further exploration of formulas to compensate for these variations may enhance predictive accuracy for lens power.
Ken Van Cleave
We have a high power plus lens of known front curve, index, and center thickness and have placed a known diameter circular target at a known distance behind the lens. Observing the circular target through the lens we compute the ratio between the diameter of the original circular target behind the lens and the measured target diameter as viewed through the lens on the other side.
Using a very small target, the focal length and power of the lens can be calculated fairly accurately using this magnification ratio along with the distance from the back of the lens to the target. The problem is that the ratio changes significantly when a larger target size is used even though the lens power is the same.
Why does this happen? Are there any formula(s) that can compensate for this so the power can still be predicted as accurately as when a very small target size is used?
Science news on Phys.org
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
