Magnitude of acceleration of a stationary mass
The discussion centers on calculating the acceleration of a stationary block subjected to an upward force at an angle, factoring in different coefficients of static and kinetic friction. The initial calculations for the forces in the x and y directions were performed using trigonometric functions of the applied force. The normal force was incorrectly derived, leading to confusion regarding the static friction and resulting acceleration. Participants pointed out errors in the approach, particularly in the calculation of the normal force and the relationship between static friction and the applied force. The correct understanding of these forces is crucial for determining the block's acceleration accurately.
peaceandlove
An initially stationary block of mass m lies on the floor. A force of magnitude 0.500mg is then applied at upward angle θ = 20°. What is the magnitude of the acceleration of the block across the floor if (a) μs = 0.620 and μk = 0.520 and (b) μs = 0.410 and μk = 0.310?
Fx=.5mgcos20
Fy=.5mgsin20
I first found my force in the x and y directions by using: Fx=Fcos(theta) = 0.5mgcos(theta)
Fy=Fsin(theta) = 0.5mgsin(theta). Since I had to find the normal force (in order to find out the static friction) i used: Fnet,y=may => Fn-Fg-Fy=may and since its not accelerating in the y direction ay=0 making: Fn=Fg+Fy => mg+0.5mgsin(theta), then i found the max static friction by using: Mu*normal force when i compared my max static friction to my Force in the x direction (since that's the only direction its moving), my static friction was less than my Fx, making a=0. And then i did that again for the second set of numbers for part b, got the same thing, a=0, but got it wrong. So i don't know what to do from there.
mg acts in the downward direction. Take its component perpendicular and parallel to the inclined plane. Perpendicular component will be the normal reaction. From this find the frictional force which is along the inclined plane. Now porceed.
Sorry. Ignore the post #2.
Since force is acted in the upward direction with angle 20 degree with horizontal, mg and Fy must be in the opposite direction. So Fn must be mg - Fy
peaceandlove: Although your approach is currently incorrect, you got the answer for part (a) correct, right? Only your answer for part (b) was wrong, true?
Fn is not equal to m*g + 0.5*m*g*sin(theta). Try again. You also said, "My static friction was less than my Fx, making a = 0." Are you sure this statement is correct?
