How Do You Calculate the Magnetic Field in a Cylindrical Conductor?
To calculate the magnetic field in a hollow cylindrical conductor carrying a uniformly distributed current I, the expression for the magnetic field in the region between the inner radius a and outer radius b is derived using Ampère's Law. The magnetic field B can be expressed as B = (μ₀ I)/(2πr), where r is the radial distance from the center of the cylinder. The current density j is defined as j = I/(π(b² - a²)). By applying Ampère's Law, the relationship B(r) * 2πr = μ₀ * j * π(r² - a²) is established, allowing for the calculation of B in the specified region. The discussion highlights the importance of understanding current direction and density in deriving the magnetic field. Overall, the derivation process emphasizes the application of fundamental electromagnetic principles.
wisper
Problem said:
A conductor is made in the form of a hollow cylinder with inner and outer radii a and b, respectively. It carries a current I, uniformly distributed over its cross section.
Question said:
Derive an expression for the magnitude of the magnetic field in the region a < r < b.
I understand that it needs to relate to the following equation but that is it. B=\frac{\mu_{0} I}{2\Pi r}
I am unsure how to derive an answer for this, I am drawing a blank on solving this. Can anyone give me any helpful hints?
what is the direction of the current? post the whole question pls...
That is the full question, the current is running through a hollow cylinder. From how I understand the current is flowing through direction of the hieght of the cylinder.
find the \ver{A} first, then B
\oint{\vec{B}\vec{dl}}=\mu_0\int{\int_S{j}}ds
and from this you can simply derive
B(r)2\pi r=\mu_0 j \cdot \pi(r^2-a^2)
where
j=\frac{I}{\pi (b^2-a^2)}.
Thanks to both of you. Clive you pointed out a part in which I made an error in my thinking of my previous answer. Appreciate the help.
