Magnitude of the Tension in a Connection String
The problem involves two masses connected by a light string, with one mass on a horizontal frictionless surface and the other hanging vertically. A force is applied to the horizontal mass, and the goal is to determine the magnitude of the tension in the string connecting the two masses.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using free body diagrams and Newton's laws to analyze the forces acting on each mass. There is mention of calculating acceleration for the system and isolating each mass to derive equations related to tension.
The discussion includes attempts to clarify the setup of the problem and the forces involved. Some participants provide guidance on isolating each mass and formulating equations, while others reflect on their previous reasoning and adjustments made to their approach.
There are indications of potential confusion regarding the setup of the problem, particularly in distinguishing between the forces acting on the horizontal and vertical masses. The discussion also highlights the importance of systematic approaches in solving such problems.
Weasler
1. Two masses are connected by a light string. The horizontal mass of 2 kilograms is being pulled to the left with a force of 30 Newtons along a frictionless surface. The vertical mass is 1 kilogram. What is the magnitude of the tension in the connection string?
2. Fnet=ma
3. My attempt was simply adding the two forces acting upon the string together; 30 Newtons and 10 Newtons respectively.
Hi there Weasler, welcome to PF! When you say vertical and horizontal mass, you mean that one mass is on a horizontal frictionless table and the other is hanging down off the table via a string a pulley? Try using free body diagrams of each mass, identifying all forces acting on each, and applying Newton's laws to solve 2 equations with 2 unknowns.
Ahhh I had seen where my logic was flawed; one would use the entirety of the system to calculate the acceleration (30-10=3a), and then take that and find the Tension between the second block (but not the first as the force is being applied to it directly and there is no friction) and the string (T-10=1*(20/3)). Thank you kindly!
Yes, your answer is correct, but sometimes you will get into trouble when first trying to isolate the system. It is best in these problems to isolate each mass separately. for the mass on the table,
(Eq. 1) 30 -T = 2a, and for the hanging mass,
(Eq. 2) T - 10 = a, then multiplying this 2nd equation by 2,
(Eq. 3) 2T - 20 = 2a. Now looking at (Eq 1)and (Eq.3), then
(Eq. 4) 30 - T = 2T - 20 , from which
(Eq. 5) 50 = 3T
which yields your same result. It may seem longer, and I can't argue with your method since you have the correct answer, but nevertheless you must proceed systematically.
