Magnitude vs Direction: Difference & Definition
  • Thread starter Thread starter OftenConfused
    Direction Magnitude
Magnitude refers to the size or length of a vector, while direction indicates the vector's orientation in space. The discussion emphasizes the importance of distinguishing between these two concepts, particularly in the context of vectors. Clarification is sought on whether the inquiry pertains to direction or distance, as these terms can often be confused. The conversation highlights the need for precise definitions to avoid misunderstandings. Understanding both magnitude and direction is crucial for accurately interpreting vector-related problems.
OftenConfused
What is the difference? I think magnitude is the distance from x right? But what is distance? total length traveled?
Science news on Phys.org
Before people start galloping off in all different directions with their answers, it might help if you clarify your question. Are you asking about vectors, by any chance? Are you asking about direction (what you have in the title) or about distance (what you have in your actual post)?
Whoops, yea it is vectors. and it is magnitude and direction.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
