Making Bar Magnets: Heating & B Field Placement
The discussion revolves around the process of making bar magnets, specifically focusing on the effects of heating, placement in a magnetic field, and the characteristics of different materials. Participants explore methods for magnetization, the identification of magnetic poles, and the properties of electromagnets.
  • Homework-related
  • One participant suggests heating metal before placing it in a magnetic field to align atoms more easily, followed by cooling to preserve magnetization.
  • Another participant clarifies that while cooling in the presence of a magnetic field can maintain magnetization, the critical temperature for iron (Curie's temperature) is around 1000K.
  • There is a discussion about the variability in magnetic properties of different types of steel, with some types being non-magnetizable.
  • Participants inquire about the optimal temperature for magnetization and suggest that room temperature may suffice when using a strong magnetic field.
  • Questions arise regarding how to identify the north and south poles of a magnet, with one participant suggesting using the Earth's magnetic field for orientation.
  • There is a claim that creating a magnet with only one pole (a magnetic monopole) has not been successful, referencing external sources for further information.
  • Participants discuss methods to dampen or insulate metals from magnetic attraction, suggesting practical experiments with various materials.
  • For electromagnets, participants mention that the direction of current flow can indicate the poles, and one participant shares a simpler method of using a compass to identify magnetic poles.
Participants express various viewpoints on the methods of making magnets and the properties of materials, with no clear consensus on the best practices or methods. There are differing opinions on the effectiveness of heating and the types of steel used for magnetization.
Participants note the influence of material composition and treatment on magnetic properties, indicating that the discussion is limited by the variability of materials and their specific characteristics.
This discussion may be of interest to individuals exploring magnetism, materials science, or those engaged in practical experiments related to electromagnetism and magnetization techniques.
cragar
If I wanted to make bar magnets would I heat up the metal and then place it in a B field of a solenoid and then cool it down in the field to keep the magnetization? It seems if i heated it up first the atoms would be more easily aligned in the B field, And then cool it down to preserve this state.
That's not quite such that atoms get lose, but, of course, if you cool the ferromagnetic in presence of external field, the magnetisation stays. Just keep in mind that for iron the critical temperature (called Curie's temp - wiki on it and on ferromagnetism!) is about 1000K.
You may just put iron in sufficiently strong magnetic field even at low temperature to keep it magnetised.
You should also know that even small changes in proportion of steel components (and even its physical trechnological treatment) have dramatic influence on its magnetic properties. Some kinds of steel cannot be magnetised at all (e.g. the steel used for cores of transformers).
So what would be the best way to make a magnet. What temp should I have it when I place it in the B field.
Just a room temperature - place your iron bar in stron magnetic field (inside solenoid).
You must play with different kinds of steel - it is pretty unpredictable. Two nails looking the same may have pretty different magnetic properties. Rule of thumb is that soft low carbon steel is easier to magnetize than springy, hard one.
im also trying to make a permanent magnet. so i have a couple of questions.
when magnetised how do you know which is the north and which is the south poles?
can you make a magnet with only one pole? north or south?
and what can dampen or insulate metals from being attracted by the magnet?
The Earth would tell you. Suspend your magnet on a thread. North pole tends to point towards North and south pole tends to point toward South.
No one ever succeed. Wiki on magnetic monopole.
Try it at home!
Put a nail into a plastic bottle and see if it is attracted by magnet.
Put it into carton box, and try again.
Put it in an alu-can and try again.
Put into steel can and try...
thanks xts . one more question
electro magnets, how do can you tell north or south? for a solenoid electromagnet to be exact.
The Earth would tell you. Suspend your electromagnet on a [STRIKE]thread[/STRIKE] wires. North pole tends to point towards North and south pole tends to point toward South.
Another way to know the poles of an electromagnet is to use the direction of current flow. At the north end, current flows in anticlockwise direction while at the south end, current flows in clockwise direction.
I've always checked magnets with a cheap compass. Far simpler than suspending the magnet from threads/wires.
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 21 ·
