Man in Elevator: What is the Force Exerted on the Elevator Floor?
  • Thread starter Thread starter Cole07
    Elevator
A 65-kg man exerts different forces on the elevator floor depending on the elevator's motion. When stationary, he exerts a force of 637.65 N, and when the elevator accelerates upward at 2.3 m/s², the force increases to 787.15 N. If the elevator moves upward at a constant velocity of 3.1 m/s, the force remains at 637.65 N, while a downward acceleration of 1.7 m/s² results in a force of 527.15 N. The discussion highlights the importance of understanding Newton's laws to determine the forces involved. The user ultimately resolved their confusion regarding the calculations.
Cole07
Force Of Man On Elevator
An 65- kg man stands in an elevator. What force does he exert on the floor of the elevator under the following conditions? The elevator is stationary.
Answer:637.65N
The elevator accelerates upward at 2.3 m/s2.
Answer:787.15N
The elevator rises with constant velocity of 3.1 m/s.
While going up, the elevator accelerates downward at 1.7 m/s2.
Answer:527.15N
The elevator goes down with constant velocity of 6.3 m/s.
EF=0
so far i have the ones where i allready have the acceleration but i don'tknow how to do the ones with velocity because i don't have a t(time) i thought maybe i could do the same and multiply 3.1m/s*65kg which is 201.5 and then use the formula EF=0 so EF=0=-201.5-637.65 which equals 839.15 but this was wrong, could you just give me an idea on how to get started and help would be greatly appreciated.
Do I not have enough work swown?
you need only to look at Newton's first law to arrive at a solution. What is the acceleration of the elevator and person when they are moving at constant speed?
how do i get to the acceleration when i don't have anything but weight and velocity?
i have figured it out thank you for your help.
