Man jumping onto a see-saw to launch bricks vertically
41 replies · 7K views
lioric
A man of mass 100kg wants to launch a brick into the air using a see saw.
He wants to launch the bricks of mass 5kg, 10 meters vertically in to the air.
The see saw is placed parallel to the ground using a support.
The bricks are placed on one end of the see saw.
The see saw is made of rigid material with a fulcrum in the center.
The see saw beam is 5m long
If the man jumps onto the far end of the seesaw (5 meters from the bricks) from a height of h meters from where he would land on the see saw.
Assume no air resistance, total energy convertion.
a) Find the value of h
b) What would be the value of h if the fulcrum was placed 1m from the bricks
c) what would be the value of h if the fulcrum was placed 1 m from where the man was to land.
W=mg
v=u+at
v²=u²+2as
s=ut+1/2at²
F=ma
GPE=mgh
KE=1/2mv²
Moment = force x perpendicular distance
Work done = force x distance moved
I drew a diagram for the a) part
The person is h meters high
So GPE= 100 x 9.8x h
GPE= 980h j
KE = 980h when the person hits the see saw
KE=1/2mv²
980h=0.5 x 5 x v²
Now it v²=u²+2as
For the brick going up to 10m
v = 0
u=?
a=-9.8ms-²
s=10m
u²=2 x 9.8 x 10
u=14m/s
We can assume that u=14m/s is the velocity that the man is when he hits the see saw
980h = 0.5 x 5 x 14²
980h = 490
h=490/980
h=0.5m
Oh crap
I used the mass of bricks for the person
980h = 0.5 x 100 x 14²
980h = 9800
h=9800/980
h=10m
Is this correct?
I assumed that the v for both sides of the see saw is same cause the fulcrum is in the middle
But don't know how to attempt it when the fulcrum is not in the middle as in part b) and c)
Please help
Thank you in advance
lioric said:
Problem Statement: A man of mass 100kg wants to launch a brick into the air using a see saw.
He wants to launch the bricks of mass 5kg, 10 meters vertically into the air.
Relevant Equations: W=mg
v=u+at
v²=u²+2as
s=ut+1/2at²
F=ma
GPE=mgh
KE=1/2mv²
GPE= 980h j
KE=1/2mv²
980h=0.5 x 5 x v²
Now it v²=u²+2as
v = 0
u=?
a=-9.8ms-²
s=10m
u²=2 x 9.8 x 10
u=14m/s
980h = 490
h=490/980
h=0.5m
Is this correct?
Please help
Are you saying that the man jumps from only ##0.5m## and reaches ##14m/s## when he hits the see-saw?
What principles are you applying here to decide what happens when the man lands on the see-saw?
Oh crap
980h = 9800
h=9800/980
h=10m
lioric said:
Oh crap
980h = 9800
h=9800/980
h=10m
You are missing something fundamental. If the brick were tied to the see-saw, then the whole system would rotate as a rigid body. But, the see-saw is not a fully rigid body. The brick will be projected into the air faster than the man lands on the other end. Why?
The physical reason is that a shockwave travels along the see-saw. This is similar to hitting a tennis ball with a racket. The ball leaves the racket much faster than you have moved your arm.
In any case, you need to find the physical laws that govern the transfer of energy from the man to the brick in this case. Any ideas? Hint: what two things are conserved?
haruspex said:
Why?
Using equations of motion it takes initial 14m/s to lift an object up to 10m
Conservation of energy and conservation of momentum
But that's the launch velocity needed for the brick. Why is that the speed of the man on hitting the seesaw? (Not saying it isn't, just querying your assumption.)
What momentum, specifically?
Be careful: are there any external forces on the system? Apart from gravity on the man and the brick? Is momentum in the up/down direction conserved during the impact of the man and the launching of the brick?
The question is is quite hard to answer if you take the physics of it seriously. Instead, it seems you are expected to rely on this utterly unrealistic assumption: total energy conversion. I interpret that as meaning all the man's lost PE is converted into man's KE, thence into brick KE, and so into brick PE. That's all you need - forget the seesaw.
I see it differently. The man collides with the see-saw loses some KE, which is transferred to the brick.
I assume we ignore any rotational KE the see-saw gains durng the short-duration collision that launches the brick.
PeroK said:
loses some KE
But how much? Seems to me they are saying "all".
Edit: @PeroK has just pointed out to me that what I am suggesting would violate a physical law. So the next option is to interpret full conversion of energy as no loss of mechanical energy. The man gets to keep some.
Combined with that other law that provides enough info for a solution.
This is question meant for a lower like grade 10
We can say that the momentum is conserved
Otherwise we'll have to take account a lot of ways energy gets wasted. So you momentum is conserved
Nope no external forces
But to makes things interesting we can say the force exerted by the brick on the could oppose the person's force
Well I saw a similar question about a contractor launching a brick to his friend
https://www.varsitytutors.com/ap_physics_1-help/gravitational-potential-energy
I used the idea from that
But I guess since the fulcrum is in the middle and we are treating the see saw as a rigid body no energy is wasted into bending the seesaw while over coming the inertia
But mainly the rigid body rotating from the center can have equal speeds equidistant from the pivot
There is an external force at the fulcrum. You can see this because the man cannot speed up, so his momentum is reduced. And, the brick is launched upwards, which equates to more loss of momentum in the downward direction. The upward force at the fulcrum, therefore, is an external force which gives an impluse to the system (of man, brick and see-saw) in the upwards direction.
This problem may be too advanced for you. You'll have to decide. The key concept you are missing is conservation of angular momentum: in this case about the fulcrum. We choose to look at angular momentum about the fulcrum because the external force at the fulcrum has no effect on this quantity.
Ya as I said this is meant for grade 10s so they haven't gone through the whole complications. They can use momentum, moment, energy and equations of motion.
And we take everything as an isolated system. No air resistance, total energy and momentum conservation.
As @PeroK has pointed out, there is an impulse from the fulcrum, so linear momentum is not conserved. What is a third conservation law?
Energy loss is not a simple question of rigid or otherwise. Nothing is completely rigid. The seesaw will behave like a spring, though a very stiff one. Energy loss in it depends on its elasticity, not its rigidity.
Sorry
Bad choice of words
I was referring to the deforming of the see saw
But I can understand
Are you referring to Newton's third law which related to conservation of angular momentum?
haruspex said:
Yes. What axis should you choose?
Y axis
jbriggs444 said:
Personally, I would attack the problem by considering the see saw with a fulcrum in the middle as an ideal massless energy-conserving force reverser. Except for the reversal of direction, it is exactly as if the falling man had collided with the brick through an ideal massless energy-conserving spring. Both rebound from what amounts to an elastic collision.
Yes that is exactly how I want this question to be attempt
By the children
So what your saying is I need to put momentum into this and treat it like a collision.
How should I try out the part with the fulcrum not in the middle?
jbriggs444 said:
In the context of angular momentum, you should understand "axis" in the sense of "axis of rotation", not in the sense of a coordinate axis.
So I guess the action of the man jumping on the seesaw would cause a clockwise moment about the fulcrum
haruspex said:
Right, but think about angular momentum about that axis. Would it be conserved and why or why not?
The man jumping down on to the seesaw would have an angular momentum of
Mass x velocity (angular) x the distance from the fulcrum.
When the brick leaves the other side the angular momentum is conserved
Keep talking. Angular momentum is conserved.
What does this mean about the brick's change in angular momentum compared to the man's change in angular momentum?
Since the man has a higher Mass and the brick is 1/20 the mass of the man, and the distance is the same for both bodies from the fulcrum, the angular momentum will be conserved by the brick having a x20 more velocity
Be careful. It is not twenty times the velocity. It is twenty times the change in velocity.
Can you write that down as an equation?
To figure out how much the two velocities change we are going to need another equation. There are two obvious choices. One assumes the equivalent of an inelastic collision. The other assumes the equivalent of an elastic collision.
Can you pick one of those assumptions and write down a corresponding equation?
Perfect elastic since KE is conserved
