Manganese Oxide mixed with HCL.
  • Thread starter Thread starter thomasxc
    Hcl Mixed
The discussion revolves around the chemical reaction between manganese oxide from alkaline batteries and hydrochloric acid (HCl). Participants explore the expected products, colors observed, and the nature of the substances formed during the reaction.
  • One participant inquires about the expected products of mixing manganese oxide with HCl, noting a discrepancy between expected pink coloration and observed green substance.
  • Another participant explains that manganese dioxide (MnO2) can react with HCl to produce chlorine gas (Cl2) and manganese chloride (MnCl2), suggesting that concentrated solutions of MnCl2 might appear green.
  • A participant asserts that MnCl2 is never green and introduces the idea of Mn(V) ions possibly being involved.
  • One participant claims that a dark green gas is released when HCl is added to MnO2, speculating that this might explain the observed color.
  • Another participant challenges the idea of observing a dark green color from chlorine gas, arguing that the gas is pale yellow-green and that the participant would likely not survive to report such an observation if the gas were concentrated enough to appear dark green.
  • A participant shares personal experimental experience, stating that they observed a dark green chlorine when mixing MnO2 with muriatic acid.
  • Another participant corrects a previous statement, clarifying that chlorine is not dark green but rather pale yellow-green, and suggests that the original poster may have been referring to a solid or solution rather than gas.
  • A final participant acknowledges the uncertainty surrounding the green substance observed by the original poster.
Participants express differing views on the color of chlorine gas and the nature of the observed green substance, indicating that multiple competing interpretations remain. The discussion does not reach a consensus on the identity of the green substance or the accuracy of the color descriptions.
Participants note the ambiguity in the original poster's description, particularly regarding whether the color observed pertains to a gas, solid, or solution. There is also uncertainty about the specific ions involved in the reaction and their potential colors.
thomasxc
Could someone please tell me What would be created when manganese oxide from an alkaline battery mixed with HCL? Theoretically, as far as I know, it should be pink, but I got a green substance.Thanks in advance
Chemistry news on Phys.org
Manganese dioxide (MnO2), from batteries, can react with hydrochloric acid (HCl) to produce chlorine gas (Cl2) and manganese chloride (MnCl2). In its hydrated form, manganese chloride tetrahydrate (MnCl2 * 4 H2O) is pink.
Perhaps when one has a very concentrated solution of MnCl2 it is green? This is just a guess, but it is the case with copper(II) salts too. For example, hydrated copper chloride forms blue solutions but very concentrated solutions appear dark green / black.
MnCl2 is never green. Mn(V) ions are...
When you add HCl to MnO2, Chlorine a dark green gas is released. Maybe that's what you saw.
If the amount of chlorine was large enough for a dark green color to be observed, OP would choke to death before getting to keyboard and reporting what he have seen.
I have personally experimented with MnO2 from a battery mixed it with Muriatic Acid and a dark green Chlorine is observed!
Chlorine is not dark green. It is pale yellow-green, but not dark. No doubts it will be observed, but the color will be not dark green.
OP wasn't clear but he didn't stated "gas", nor "choking gas", so I guess he referred to the color of a solid or solution.
I stand corrected. I guess thomasxc's green substance is still a mystery!
  • · Replies 21 ·
