How Do Inductors L1 and L2 Affect H-Bridge Output in a Resonant LC Tank Circuit?
  • Thread starter Thread starter sina_stuck
    Inductor
Inductors L1 and L2 in an H-bridge inverter circuit influence the output square wave shape, amplitude, and phase as they connect to a parallel LC tank at a resonance frequency of 200 kHz. These inductors affect the driving signal that the LC tank receives, altering its waveform characteristics. The amplitude of the output square waves is also modified, impacting the voltage seen by the LC tank. Additionally, L1 and L2 introduce a phase difference between the H-bridge output and the LC tank input. Understanding these effects is crucial for analyzing circuit behavior and optimizing performance.
sina_stuck
Hi,
The following circuit is the the very basic form of an Hbridge inverter driving a parallel LC tank at its resonance frequency 200khz. The Inductors L1 and L2 are put in series between the square wave output of the Hbridge and the parallel resonance LC tank now I have the following three questions about L1 and L2:
1.How they change the shape of hbridge output square waves(what driving signal shape LC tank sees)?
2.How they change amplitute of hbridge output square waves(what amplitude the LC tank sees)?
3.How they change phase of the hbridge output square waves(what phase difference they introduce between hbridge output square waves and the LC tank input driving waves)?
I want to first understand the concepts and then learn the related equetions.
Any body able and willing to answer the questions and I will discuss it in more detail.
thank you in advance
sina_stuck said:
Hi,
This appears to be related to your thread last month on induction heating:
https://www.physicsforums.com/showthread.php?t=480386
What do you think the answers are to your questions listed above?
Yes, Its related. What do you mean what I think about the answers...I've tried a lot of simulations but without knowing how it works it doesn't seems to be usefull.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
