Bicycle Questions: Static Friction & Gear Ratios
  • Thread starter biq1
  • Tags
    Bicycle
In summary, static friction can do work in certain situations, such as when a bicycle is accelerating. However, in the case of a bicycle, some of the work of friction is transformed into thermal energy, while the rest is used to increase the translational kinetic energy of the bicycle. This is due to the friction force acting at the bottom of the tire, which does not move, but the center of mass of the bicycle does. This phenomenon is possible because the kinetic energy necessary for the bicycle to move is supplied by the person riding it, not by external work. Additionally, in situations where no external work is done, such as a box on an accelerating car or a bicycle with no friction, the source of the energy is internal.
  • #36
A.T. said:
The work done by the chain on the wheel is greater than the work done by the wheel on the bike frame. The reminder goes into accelerating the wheel.
Thats unclear to me, it seems to me that the so called reminder goes into rotational acceleration.
  • #37
nasu said:
The internal forces can change KE...
I don't seem to get this sorry. Can u explain it abit more. Ok at first glance they seem they can change total rotational KE but i am not sure about the TOTAL translational KE.
You need an external force not to change KE but to change the momentum. Or the momentum distribution, if you wish. The external force will "produce" a linear momentum and its torque around the CM will prevent the bicycle to rotate as a whole. The normal force contribute too, not only the friction.
Well as you say we need external force to change linear momentum, thus the magnitude of velocity thus the translational KE. I ve to say this is the point where it gets hard for me to grasp, how is it possible for the external force to change the linear momentum but not the translational KE.
  • #38
mattt said:
This.
It is not that difficult to understand.
Well as i said in other posts for me personally the hard point to understand is how this external friction force does the redirection of energy without doing any work.
  • #39
It is exactly the same when you start to walk. The exterior force (static friction) changes the total linear momentum (of you), but the work of this static friction force is zero.
The total work (which in this case is equal to the work done by internal forces) is not zero, and it is just equal to the change in total kinetic energy (from 0 when you are at rest, to some KE when you start to walk).
They are just two different theorems:
[tex]\vec{F}_{ext}(t) = \frac{d \vec{P}(t)}{dt}[/tex]
(that is, the total exterior force is equal to the rate of change of the total linear momentum vector of the system of particles, assuming internal forces are "Newtonian").
[tex]\int_{t_0}^{t_1}\vec{F}(t)\cdot\vec{v}(t)dt = \Delta KE[/tex]
(that is, the total work, sum of all works of all forces on all particles, is equal to increment in total kinetic energy of the system of particles).
They are two different mathematical theorems and they state different things.
  • #40
Linear and rotational. Or just assume a massless wheel, which doesn't require energy to accelerate.
  • #41
Consider a stick falling over under gravity, with the lower end fixed on the ground.
  • #42
Νοw that you mentioned this you made me think in terms of impulse. So from that relation follows [tex]\vec{p(t)}-\vec{p(0)}=\int_0^t{\vec{T(t)}}dt[/tex]. So its the impulse of friction T(t) that changes the linear momentum of the bike (since there are no other external forces on the x-axis). So if friction is zero the impulse is zero hence p(t)=p(0)=constant, hence translational KE also constant.
However if the friction is not zero then it follows that the change in the linear momentum (hence the change in translational KE=p^2(t)/2m) is due to the impulse of the friction. We need not provide work from internal forces to increase translational KE.
  • #43
Delta² said:
... changes the linear momentum of the bike...
If you have a body called "bike" in your model, which combines the entire bike and rider into one translating block, then the horizontal ground force will do work on this body, because the interface between "bike" and ground is not static anymore in this coarse model. It doesn't matter that it could be treated as static friction in a more detailed model with wheels, because in physics you do calculations based on your actual model, and not on some extra info that you didnt include in the model. And this coarse model discards the information about how wheels work, and the details of their interaction with the ground, so this interaction is not modeled as static friction anymore.
  • #44
Τhat equation holds regardless of the modeling of the bike or whether you apply it only to wheel or the whole bike, since there arent any other external forces. To make you see it better, notice that the impulses due to internal forces will cancel each otther and only the impulse of external force will remain. To make u see it even better i ll apply it to the wheel and the rest of bike separately and i assume only the internal force between the wheel and the axis (you can also include the internal force of the chain but the treatment will be similar because one end of chain is on the wheel while the other end of chain is on the pedal which is on the rest of bike). So for the linear momentum of the wheel it will be
P_w(t)-P_w(0)=impulse(T,t)+impulse(F_internal,t)
and for the linear momentum of the rest of bike will be
P_b(t)-P_b(0)=impulse(-F_internal,t). Adding those two together the two impulses of F_internal will cancel out and what will remain will be the equation we want. ( I am really busy now and i avoid typing in tex, sorry anyway).
  • #45
That statement is misleading (to say the least). If there were no internal forces (in the man + bicycle system) or just if the work of internal forces were zero in this system, then the bicycle and man would remain at rest and total KE would remain as zero.Exactly the same in the "man or robot starting to walk" case. If there were no internal forces or just the work of these internal forces (in the man or in the walking robot) were zero, then the man (also the robot) would not move. Total kinetic energy would remain as zero.The problem, more than anything, is "the way you state it". I think you already know that in this system (man + bicycle, or equivalently "man or robot starting to walk") the work of the static friction force is zero, that the static friction force is equal to the rate of change of total linear momentum vector, and that the work of all internal forces is equal to the increment of total kinectic energy. I think you understand all these facts, but you "decide" to state it in a very misleading way.
  • #46
To tell you the truth i just don't know. Maybe i am wrong on how i am thinking and how i am stating things. This thread has tired me. Deep down what i understand is that regardless if it is exactly one or more contact points, friction "steals" rotational kinetic energy from the back wheel and gives it as translational (and probably the opposite is happening in the front wheel where we don't have chain to do work, there friction counteracts the force of the axis and gives it back as rotational kinetic energy). Oh well i am just tired, maybe when i come back in this thread after some weeks and i read again i understand better.
  • #47
You equation is about momentum, not work.
  • #48
For Delta²:
Internal forces can change the total kinetic energy of your system. Whereas they can never change the total momentum of it, only external forces can do that. There's no contradiction here they are just two different theorems, as someone stated above. I think what's confusing you is the differentiation you make between "translational" and "rotational" kinetic energy, ultimately they are the same thing, namely energy due to motion of material particles.
Consider a system composed of a spring attatched to a block, with the spring against a wall, when you compress the spring and release it, the "translational" kinetic energy of the block + spring system increases, the only external force here is the normal from the wall, would you say that force does work?
  • #49
nearlynothing said:
For Delta²:
Oh well i am tempted again to write in this thread...
Nice example. I could say again that the impulse of the normal changes the momentum of the system and since at least in this case the total translation kinetic energy is p^2/2M the impulse is what changes the kinetic energy of the system.
There is some sort of other thing that puzzles me also: What is happening to the work of the force from the block to the spring? It appears to me this work is negative yet it increases the kinetic energy of the spring (work from the normal is zero anyway). We have a violation of the work-energy theorem (applied to the spring only) or the theorem doesn't hold in the case of spring?
Also back to the bike . I wonder what is happening to the front wheel where there is no chain attached. How this weel is gaining rotational kinetic energy? Does the friction via its torque do work in the front wheel? I really don't understand the work of the torque of friction is different from the work of friction in this case?
  • #50
Yes, that was the first of the two mathematical theorems I wrote in an earlier post.
After the interaction (when the spring + block leave the wall) the kinetic energy of the system will be [tex]\sum_{i}\left(\frac{1}{2}m_i v^2_i\right)[/tex]
if all the particles move with the same velocity vector (which will be equal to the velocity vector of the center of mass) then that is the same as p^2/2M, but in this example it does not hold.
(the spring, if ideal, will for ever be compressing and stretching after it leaves the wall).
But you still are confused about the following:
You seem to think that the change in total kinetic energy of a system of particles is a function of the total linear momentum vector change. That is not correct in general. That is true only when (before the interaction, and also after the interaction) all the particles of the system have exactly the same velocity vector, which will be equal to the velocity vector of the center of mass.
In a given system of Newtonian particles, the same change in total linear momentum vector can result in totally different changes in total kinetic energy of the system.
Imagine this very simple example:
A system of two point particles at rest with different masses:
Particle 1 is at rest at [itex]P1(0,1)[/itex] (for example), and particle 2 is also at rest at [itex]P2(0,0)[/itex]. Imagine that mass of particle 2 is = 2* mass of particle 1.
case 1: A constant force [itex]\vec{F}[/itex] (horizontal, to the right) is exerted on particle 1 during a time interval [itex][t_1, t_2][/itex].
case 2: That "same" force (only difference now will be the point of application) is exerted on particle 2 during the same time interval.
(for simplicity, imagine there are no internal forces in this example).
The change in total linear momentum vector of the system will be exactly the same in case 1 and case 2.
But the change in total kinetic energy of the system will be different in case 1 and case 2 ( in case 1 the total kinetic energy change will be = 2* total kinetic energy change in case 2 ).
So the "same" force (only difference being the point of application) acting during the same time interval, produces exactly the same change in total linear momentum vector of the system, but it produces (in this simple example) double of change in total kinetic energy of the system in case 1 wrt case 2, depending on the point of application of this "same" force.
I hope this helps you to understand the subtleties of these concepts.
In the "spring + block system", the exterior force (the normal force the wall exerts on one end of the spring) is equal to the rate of change of total linear momentum vector of the system (ignoring gravity for simplicity). But the work of this normal force is zero.
The total change in kinetic energy of the system is equal to the total work of all internal forces in this case.
Try to think about the whole system made up of thousands of point particles (this always helps). Put your attention to one concrete given particle (it does not matter if it is a particle of the spring or a particle of the block). During the time interval when the spring is stretching and about to leave the wall (i.e., during the interaction wall-system), this particle you are putting your attention on, is accelerating to the right (imagine the wall is vertical and the system is at the right side). That is because the total force on this concrete particle during this time interval, is non-zero and pointing to the right (and this total force on this concrete particle is equal to the total INTERNAL force on this concrete particle, ignoring the weight for simplicity).
Obviously the work of this total force ( = total internal force ) on this concrete particle (of the spring or of the block, it is the same) is not zero, it is positive.
If you think exactly the same with ANY other particle of the spring or of the block, you realize the total work of internal forces is obviously non-zero, it is positive, and it is equal to the total change in kinetic energy of the system.
It is a mathematical theorem. It can not be violated :-)
It could not apply depending on the mathematical-physical hypothesis of our model, but in this example-model, it does apply.
I will explain this later, I got to go now.
  • #51
If you look at center-of-mass work (force times displacement of the center of mass), the work-energy theorem applies. The net force on the spring from the wall and from the block combined is away from the wall. The center of mass moves away from the wall. Positive center-of-mass work is done and linear kinetic energy increases.
If you look at total work (force times displacement of the material at the point of contact), conservation of energy applies. The wall does zero work on the spring and the block does negative work on the spring. It must be so to balance the energy books. The block carried away kinetic energy and that energy had to have come from somewhere. The potential energy of the spring makes up for the resulting energy deficit.
You can easily see that the work done by the block is negative -- were it not for that interaction, the spring would *ZING* across the room with essentially all of its potential energy having been converted to kinetic and vibrational energy in the spring and none having been converted to kinetic energy in the block.
Always keep straight which kind of work you are talking about.
  • #52
The kinetic energy of the spring comes from internal work of the spring (stored potential energy), not from the work of the block on the spring.
How do you gain rotational kinetic energy, when somone pushes you over? In the rest frame of the ground, the bike frame is doing work on the front wheel. It applies a force at the axle, which creates a torque around the static ground contact point.
  • #53
You're right in what you mean, but you're saying it incorrectly. In general, kinetic energy changes as a result of work of some force. The interesting thing about this is that the force can be any force, even internal force. In the case of block with a spring, the kinetic energy of the block increases as a result of the force due to spring. The kinetic energy of the spring increases due to work of internal stress forces in the spring on the spring itself.
This work is negative, so it cannot be the sole work done on the spring! There is additional work done on the spring due to internal elastic forces. The work-energy theorem is valid, we just have to include all mass points and all forces that act on them.:smile:
In the frame of the road, the fork pushes the axis forward and since the axis moves in the direction of this force, the fork does work on the axis. Friction force enables transfer of part of this work to rotational energy, but it does not contribute any work of its own.
  • #54
To Delta^2:
As you can see in the last answers, you can "translate" from a "microscopic view" (system of point particles, the way I tried to explain it to you) to "macroscopic view" (talking about "the spring", "the block", the work this subsystem "does" on this other subsystem,...the way the last few posters tried to explain it to you) and vice versa.
They are equivalent ways of stating the same things (the same results), if done correctly, obviously.
Depending on the person, some find it easier to "look at it" from the "microscopic=system of point particles" point of view, some others find it easier to "think about it" from the "macroscopic=subsystems doing work to each other" point of view.
As I said, if done correctly, it is totally equivalent.
Personally, when I start to have some doubts about a given problem (in Newtonian mechanics), I usually see it more clearly when I go down to the "microscopic"="system of point particles" point of view. But probably other people feel the other way around :-)
  • #55
Good answers regarding the kinetic energy of the spring, however i am not satisfied about the other two questions.
As even matt stated, changes in the linear momentum vector result in changes in translational kinetic energy. The change in translational KE is always a function of the momentum, which exact function depends in the case.
So still can say impulse of external forces changes momentum p which changes translational KE(p).
Jano.L sorry you have to explain better how the friction which is applied at the contact point in the ground, transforms the work of the force from the fork to the axle into rotational kinetic energy. What i see is that the torque of friction gives rotational acceleration and that the force from the axle gives no torque. Its kinda the same situation, we have the friction which changes the angular momentum of the wheel which changes the rotational kinetic energy of the wheel which is function of its angular momentum.
  • #56
Did you really read my post? :-)
I said change in total kinetic energy of a system of particles IS NOT a function of change of total linear momentum vector of this system of particles.
I even wrote an example of a system in which THE SAME change in total linear momentum vector give rise to two totally different changes in total kinetic energy of the system.
I even stated when it is and when it is not. :-(
More on this later on.
  • #57
yes i read your post and jano.l's which both i found most usefull to me. I read also the other two posts but were rather confusing or i didnt find em satisfying.
Matt, can you find me a case where we have a change in the magnitude of the linear momentum, yet we have no change in the translational KE?
What i am saying is that
external impulse cause change in linear momentum which cause change in translational KE.
It doesn't matter if the same change of momentum in two different cases cause two different changes in KE , all it matters is that it causes the change.
  • #58
If I understand correctly, you're saying that without this external force which changes the momentum, and so changes the velocity, there wouldn't be a change in traslational KE, so that the external force must be the factor that indeed changes the traslational KE, and so we can say that it performs work. Tell me if I'm wrong.
The problem here is that then you have to define work done by a force as "the amount of change in the kinetic energy that wouldn't happen without this particular force". That's not the definition we use in physics. It would be a pretty hard to apply definition also.
  • #59
Hm no, i am saying an external force changes momentum which in the general case changes the KE. So i require some explanation how this happens whithout the external force doing work. Some answers are confusing some are satisfying, overall i can't say i have a clear picture. Maybe i can ask it more clear , is it possible for an external force to change the magnitude of the total linear momentum without doing work?
I guess it is all we need is impulse and not work such as in the case of the normal of wall in your example.
  • #60
Yes.
Imagine two point masses:
Particle 1 of mass = 1 Kg is at rest at point [itex](0,1)[/itex] and particle 2 of mass = 2 Kg is moving horizontally to the left at constant velocity [itex]\vec{v}_2 = -\frac{1}{\sqrt{2}} \vec{i}[/itex] m/s.
Suppose there are no internal forces in this example.
An exterior force [itex]\vec{F}_a = 1 \vec{i} N [/itex] acts on particle 1 during 1 second of time.
Another exterior force [itex]\vec{F}_b = \sqrt{2}\vec{i} N [/itex] acts on particle 2 also during 1 second of time.
Before the exterior forces are applied, we have:
[itex]\vec{p} = \vec{p}_1 + \vec{p}_2 = \vec{0} + m_2\vec{v}_2 = 2 \frac{-1}{\sqrt{2}}\vec{i} = -\frac{2}{\sqrt{2}}\vec{i} = -\sqrt{2}\vec{i} [/itex] Kg m/s
After the exterior forces have been applied, we have (do yourself the computations) :
[itex]\vec{p} = \vec{p}_1 + \vec{p}_2 = 1 \vec{i} + \vec{0} = 1 \vec{i}[/itex] Kg m/s
So the total linear momentum vector has changed in magnitude (and also in sense).
The total kinetic energy before the exterior forces have been applied was:
[itex]\frac{1}{2}m_1 v^2_1 + \frac{1}{2}m_2 v^2_2 = 0 + \frac{1}{2}2\frac{1}{2} = \frac{1}{2}[/itex] J.
The total kinetic energy after the exterior forces have been applied is:
[itex]\frac{1}{2}m_1 v^2_1 + \frac{1}{2}m_2 v^2_2 = \frac{1}{2}.1. 1^2 + 0 = \frac{1}{2}[/itex] J.
So the total linear momentum vector has changed in magnitude, but the total kinetic energy of the system remains the same.
As you can see in this last example, that is not true. :-)
  • #61
Anyway, the example of one single wheel rolling on an horizontal ground is even more interesting.
I guess you are perplexed that if the wheel is rolling (without sliding) and the only exterior forces acting on the wheel are the weight, the normal force and the static friction force, how is it that the wheel end up stopping if the only force that causes a non-zero torque (wrt COM) is the static friction force and it "should" increase the angular velocity (the angular momentum vector) ? :-)
Or imagine you are pushing the center of mass of the wheel so that the center of mass is moving with uniform rectilinear motion. Again, the only force (apparently) that causes a non-zero torque (wrt COM ) is the static friction force and, again, it "should" increase the angular velocity (angular momentum vector), how is it that the angular velocity remains constant? :-)
As I said, this example is good enough to test many things about Newtonian mechanics. I'll leave it to you to think about it and later on I'll comment on this example. :-)
  • #62
When you push a standing person at his center of mass, the friction at his shoes transforms the work you do into rotational kinetic energy. Do you understand that?
Delta² said:
What i see is that the torque of friction...
You confuse reference frames. In the ground frame the instantanious center of rotation is the point where the friction acts, so it creates no torque around that point.
  • #63
No. What is the definition of "Force A transforms the work of Force B" there is no such definition in physics. There is Force A does work, or Force A creates Torque, or Force B gives impulse.
i can choose whatever frame i want and a constant point in the frame to take the torques of the forces.
  • #64
mattt said:
Yes.
yes ok it might not be true in ur example but it still hold in the case of our interest with the bike.
  • #65
The issue here is that rolling involves surfaces that move with respect to each other. Any point on the wheel is moving in a cycloid path, and over the period of time for each revolution of a wheel, the average velocity of any point on the wheel relative to the ground is the same as the average velocity of the bike relative to the ground.
There's no claim the ground is performing work (assuming a ground based frame of reference), it's the internal energy source that is doing the work, exerting a backwards force onto the ground, and with the Newton third law reaction of the ground exerting an equal but opposing forwards force onto the wheel. Here's a link to a web article about this:
http://electron6.phys.utk.edu/101/CH2/wheels.htm
Another example of this would be a solid uniform sphere rolling up or down an incline without slipping. The total change in energy of the ball equals m g Δh, composed of linear and angular energy. The change in the angular component of energy is due to the static friction force exerted by the incline onto the ball opposing the gravitational component of force, and equals the static friction force times the distance rolled. Similar to above, there's no claim that the incline is performing work, in this case gravity is responsible for the change in energy.
Yet another example would be a solid uniform sphere rolling on the accelerating surface of a very long treadmill. In this case, the treadmill is the source of energy. The center of mass of the sphere will accelerate at 2/7th's the rate of acceleration of the tread mill, relative to the non-moving ground. The static friction force times the distance moved relative to the non-moving ground will equal the change in linear kinetic energy of the sphere (relative to the ground). The static friction force times the sphere surface distance rolled (or torque times angular displacement) will equal the change in angular kinetic energy of the sphere.
  • #66
Ok, but sorry what is the point of this point?
Ok fine ground does not perform work. The internal energy is doing work and is keeping the friction force alive (thats what you saying if i understand correctly). Does the friction force gives impulse or the impulse is zero also? And if the impulse is zero how the momentum of the bike is changing?
Also in the link you gave when it says "Sliding friction converts (or transforms) most of the work you do on the file cabinet into thermal energy" it admits that the sliding friction does work. Anyway that's for sliding friction. What the intersting portion for me in this link is :
"##How can the force of static friction be responsible for accelerating the car and do no work? Internal forces between different parts of the car in the engine, transmission, etc, come in action-reaction pairs. These forces can do work. The frictional force can cancel one of the forces of an action-reaction pair with a direction opposite to the direction of the acceleration, leaving a net force in the direction of the acceleration."
Ok fine friction cancels one of the forces in an action-reaction pair, but how it cancels the work of that internal force, since the friction doesn't do work?
So though again the friction does no work you saying that the changes in energy equal to some sort of "pseudo work" of friction right?
  • #67
Delta² said:
No. What is the definition of "Force A transforms the work of Force B" there is no such definition in physics. There is Force A does work, or Force A creates Torque, or Force B gives impulse..
When you push someone over, the friction at his feet acts as a constraint which enforces a certain movement (rotation), but does no work on him in the rest frame of the ground. Do you understand that?
Delta² said:
i can choose whatever frame...
The rule that static friction does no work applies in the rest frame of the contact surfaces. In other frames it can do work.
  • #68
Yes. It doesn't matter that the ground is not the source of energy when the ground exerts a forwards force in reaction to the wheel exerting a backwards force. The net impulse on the bike will be the forwards friction force x time and the net change in energy of the bike will be the forwards friction force x distance traveled relative to the ground (well almost, a tiny amount of the energy change goes into the earth).
The friction doesn't cancel one of the forces. The backwards force exerted by the wheel onto the ground affects the earth. The forwards force exerted by the ground onto the wheel affects the bike. The change in momentum of Earth and bike cancel each other, since the Earth and bike can be considered a closed system with no external forces. Almost all of the change in energy goes into the bike since the Earth is so massive that the change in momentum (equal and opposite of that of the bike) results in a very tiny change in speed.
Rolling motion complicates this. In the rest frame of the ground, the average velocity of any point on the surface of the wheel during the time it takes to make some integer number of revolutions is the same as the average velocity of the bike during that time period.
  • #69
Ok guys let me get this straight.
Total translational KE changes (in some cases) as the result of the work of only internal forces, however total linear momentum changes only by the impulse of external forces (impulse doesn't have work as consequence necessarily).
I have to say the more i think of this the more weird and strange it looks to me. I don't know why.
  • #70
But that's what it says at the link. The way you describe it now makes it look to me like the friction(force from ground to the wheel) changes the energy of the bike. Ok hm i guess the friction redirects most of the energy back to the bike via its impulse not work. (Problem here is that there is not official definition of a force that redirects or transforms work or energy but oh well wth)
  • Classical Physics
  • Mechanical Engineering
  • Classical Physics
