Mass hanging by two ropes, find rope tensions.
  • Thread starter Thread starter aitee
    Mass Rope
A steel beam weighing 1400 kg is suspended by two ropes at angles of 20 degrees and 30 degrees from the vertical. The weight of the beam is calculated using Newton's second law, resulting in a force of -13720 N. The tension forces in the ropes must balance both the horizontal and vertical components, leading to equations that relate the tensions R1 and R2 to the weight. The discussion clarifies the use of sine and cosine for resolving the components of the forces, emphasizing the importance of correctly identifying the axes. Ultimately, the participant resolves their confusion by properly applying the component equations to find the tensions in the ropes.
aitee
There is a steel beam of 1400kg hanging from the ceiling by two ropes. The first rope (R1) is 20 degrees to the left of the steel attach point, the second rope is 30 degrees to the right of the attach point.
Here is the diagram: http://img202.imageshack.us/img202/7654/06p29.jpg
The relevant equations would be Newton's second law, F = ma
Fx = F cos(theta)
Fy = F sin(theta)
This are all the relevant equations as far as I know.
First, I found W (weight, the force of gravity on the object) by simply using Newton's second law: F = ma where m = 1400kg and a = -9.8; with that I get W = -13720N
As the steel beam is not moving side to side, R1x = R2x Fnetx = 0
Because the tension is holding the steel beam in the air, the x-components of R1 and R2 must be equal to W. So: W = R1 cos 20 + R2 cos 30
Is this correct so far?
This is the part I get stuck. I know neither R1 or R2 and am not sure where to go.Any help would be appreciated so much.
Fx = F cos(theta)
Fy = F sin(theta)
yes, but you seem to be considering the vertical axis as the x axis, which is OK, but uncoventional
Put R1x and R2x into their vector component form , just like you did in the vertical direction, and solve the 2 equations with 2 unknowns.
Oh, I meant to be doing y.. Our teacher (she's confusing) said that because the angle is not along the x-axis and is on the other side of the vector that the y component would be cos instead of sin..
Sorry, I'm not trying to do it in an unconventional way, I want to do it the simplest and most straightforward way possible.
What I mean is, sin(30) == opposite/hypotenuse; so in the diagram (using a triangle) this would be Fy = F sin 30 == (F hyp)*(parallel to the x-axis opp) /hyp
Does this make sense? Like am I understanding why the component equation is what it is?
We use sin because is opp/hyp and when we multiply that by the vector magnitude(which is the hypotenuse) it results in opp; which is the component we were looking for in the first place?
Your teacher is correct..the y (vertical) component of Rope 2 is R2(cos 30) or R2(sin 60)...same result. Proceed as you were doing, just keep your components straight...and axes...
Thanks, I got it figured out now. I just had to get each component in the form Fx/y = F cos/sin(theta) and then set each equaling both W and zero and plug one into the other.
I'm not sure why I was so confused in the first place, hindsight--blah.
Thanks again.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
