Does Heat Energy Increase the Rest Mass of a Substance?
nhmllr
I've heard that if you heat up a substance it masses very slightly more, because of E = mc2, and the ebergy added is in the form of heat
I am just curious - could you also think of it as m = m0 / \sqrt{1 - v^2 / c^2} because heat energy is just really diffuse kinetic energy on a molecular scale, and the small sums of all of the masses added is measurable given extremely precise instruments?
I would assume you are correct, but remember that having more mass doesn't change the rest mass, or invariant mass, or whatever you want to call it.
Right, but rest mass is the mass measured by an object also moving at the same velocity, which is impossible when ever molecule has a different velocity vector.
If you add heat to a body, you *do* increase its rest mass.
To take the simplest nontrivial case, suppose you have a system of two particles, each of rest mass m, moving in opposite directions at speed v. Taken as a single unit, these two particles have a rest mass of more than 2m.
Ah ok. I was thinking of adding energy in the form of velocity to the whole object, not heat. Sorry.
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
