Mass moment of inertia of a composite shape
The discussion revolves around calculating the mass moment of inertia (MMoI) of a composite shape, specifically involving a rectangle and a quarter circle. Participants are exploring the application of the parallel axis theorem and the necessary steps to find the MMoI about different axes.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss calculating the MMoI of the rectangle and the quarter circle, with some expressing uncertainty about applying the parallel axis theorem correctly. There are attempts to clarify how to find the MMoI about the centroid and the x-axis, as well as considerations of symmetry in the problem.
Some participants have provided insights into the process of using the parallel axis theorem and the importance of determining the mass center. There is an ongoing exploration of different methods to approach the problem, including suggestions to find the MMoI of individual components separately.
Participants note the need to consider the thickness and density of the material after determining the combined centroid of the shape. There is also mention of specific problem references that may aid in understanding the concepts involved.
marcadams267
What is the mass moment of inertia (kg-m^2) of the following steel plate about the x-axis
Mass moment of inertia of a quarter circular plate about its base is (1/4)mr^2
Mass moment of inertia of a rectangle along its base about the x-axis is(1/3)mh^2
thickness of the steel plate is 5mm
density of steel is 7850 kg/m^3
My thought process was to get the mass moment of inertia of the rectangle and then subtract the mass moment of inertia of the quartercircle from it.
The MMoI of the rectangle is:
(1/3)(0.005*7850*.6*.3)(.3^2)= 0.212 meters
The MMoI of the quartercircle is:
(1/4)(0.005*7850*¼π 0.3^2)(.3^2) + ?
My problem is that I'm not sure how to apply the parallel axis theorem to get the Mass moment of inertia of the quarter circle about the x-axis.
Pay attention to units.
To use the parallel axis theorem you need to know where the mass centre is.
I understand now, since I only know the mass moment of inertia about the base of the quartercircle, I first have to use this to find its mass moment of inertia about its centroid. Then I use this mass moment about the centroid to find the mass moment of inertia about the x-axis.
I have to apply the parallel axis theorem twice.
Yes.
I looked for a way to avoid this in the present case by using some symmetry arguments, but failed.
Lnewqban said:
Take a look at problem #2 of this site:
https://owlcation.com/stem/How-to-Solve-Centroids-of-Compound-Shapes
I would leave the inclusion of the thickness and density of the material for after finding the combined centroid of the irregular flat shape.
I would not recommend to find the centroid of the entire lamina. For moments of inertia of compound shapes it is almost always simpler to find the MoI of each simple piece separately and sum. So here I would find the centroid of a semicircle, hence find the MoI of a semicircle about a tangent, etc.
  • · Replies 28 ·
  • · Replies 40 ·
  • · Replies 21 ·
