Mass of a block via kinetic friction
The discussion revolves around calculating the mass of block B connected to block A, which is sliding down an incline at a constant speed due to kinetic friction. Block A has a mass of 5.9 kg and a coefficient of kinetic friction of 0.36 on a 43° incline. The user is attempting to determine the tension in the system to find block B's mass but is struggling with the equations of motion and forces acting on both blocks. They note the absence of a normal force on block B, complicating the calculations. The conversation emphasizes the importance of analyzing forces parallel and perpendicular to the incline for accurate results.
AnkhUNC
[SOLVED] Mass of a block via kinetic friction
In Fig, two blocks are connected over a pulley. The mass of block A is 5.9 kg and the coefficient of kinetic friction between A and the incline is 0.36. Angle θ of the incline is 43°. Block A slides down the incline at constant speed. What is the mass of block B?
http://edugen.wiley.com/edugen/courses/crs1650/art/qb/qu/c06/fig06_34.gif
OK so I'm unsure of how how to compute this question. I'm going to need to find the tension in this problem in order to find the mass of block two correct?
So for m1:
Fy = N-mg+(Tsin43-(Tsin133 [90+43 for the Fk force]*.36))
How do I solve for T here if I don't have a second equation to help me solve? There isn't a normal force on block B seeing as it is in the air so I couldn't impose the two to get rid of N right?
Fx = Tcos(43)-Tcos(133)*.36
Is this correct?
For m2:
Fy = T-mg
Fx = No movement
T>mg or block A would not be in kinetic friction.
Thanks,
AnkhUNC said:
So for m1:
Is this correct?
This will be a bit easier to analyze using axes that are parallel and perpendicular to the plane, instead of horizontal and vertical.
For m2:
Fy = T-mg
Fx = No movement
If T > mg, the blocks would accelerate.
Well that's sort of what I'm trying to do. I'm making the friction and tension south west and north east respectively. I kind of figured the way I set that up was incorrect but I haven't had to do two forces at the same time before.
For mass A, choose your x-axis as parallel to the incline and your y-axis as perpendicular. Then only the weight will need to be broken into components.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
