Mass of disk given mass per unit
To find the mass of a disk with a hole, the user calculated the mass per unit area for both the whole disk and the hole, then subtracted the hole's mass from the whole disk's mass. Initially, the user incorrectly used the diameter instead of the radius in their calculations, leading to an incorrect total mass of 5.03 kg. After realizing the mistake, they recalculated using the correct radius, resulting in a total mass of 1.256 kg. The discussion also briefly touched on the formula for the area of a circle. The final mass calculation reflects the importance of using the correct dimensions in area calculations.
aaronfue
I need to find the mass of a disk with a hole, given inner and outer diameters of 0.10m and 0.30m, respectively. The disk has a mass per unit of 20 \frac{kg}{m^2}.
Since I needed mass units, I thought that I could multiply the mass per unit by the area of each disk, the disk as a whole and the missing hole. (The missing will be subtracted from the whole)
So,
Whole disk:
20 \frac{kg}{m^2} × \pi × 0.30 m2 = 5.65 kg
Missing hole:
20 \frac{kg}{m^2} × \pi × 0.10 m2 =0.628 kg
Total mass of disk:
5.65 kg - 0.628kg = 5.03 kg
Is this correct?
I will also have another question that I will need answered related to this but I will try it on my own and provide my calculations.
Thanks for the help!
What is the formula for the area of a circle?
Area of Circle: \pir2
And have you used the correct r in your calculations? Hint: Read the OP again very carefully.
Oh...I used the diameter instead of the radius!
20\frac{kg}{m^2} × 0.152 = 1.414 kg
20\frac{kg}{m^2} × 0.052 = 0.158 kg
Total mass: 1.414 - 0.158 = 1.256 kg
