Mass of gas required to lift another mass
  • Thread starter Thread starter bray d
    Gas Lift Mass
To determine the minimum mass of gas required to lift another mass using a balloon, the relationship m=(MG)/(A-G) is established, where G is the gas density, M is the mass to be lifted, and A is the atmospheric density. The lifting force is feasible since the gas density is lower than the atmospheric density. Initial attempts to apply numerical values to the equation were challenging, but ultimately led to a solution. The discussion emphasizes understanding density relationships in buoyancy. The problem is resolved by recognizing the necessary conditions for lift.
bray d
[SOLVED] mass of gas required to lift another mass
A balloon contains gas of density G and is to lift a mass M, including the balloon but not the gas. Show that the minimum mass of gas required is m=(MG)/(A-G) where A is the atmospheric density.
Basic density mass relationships?
Obviously the density of the gas is less than the density of the atmosphere, thus the lifting force is possible. I'm just having a hard time seeing the relationships without actual numbers. I tried applying numbers to the situation but that hasn't seemed to help, like making G=.5 and A=1. I need a witty suggestion to jump start me. Thanks
Figured It Out!
