Mass of Nuclide Remaining After a Fraction of a Half-Life
To determine the mass of CaCO3 needed for an experiment with 47Ca, which has a half-life of 4.53 days, one must account for the time it takes for delivery. The calculation shows that 50 hours corresponds to approximately 0.4599 half-lives. After applying the decay formula, the remaining mass of 47Ca is calculated to be 0.727 of the original amount needed, leading to a required mass of 4.47 μg. However, there is confusion regarding the correctness of this answer, suggesting a need for careful review of the problem statement. The discussion emphasizes the importance of accurately interpreting the question to avoid errors in calculations.
jzwiep
You want to do an experiment using 47Ca (half-life=4.53 days). You will need 3.25 μg of the nuclide. What mass of CaCO3 (100% enriched in 47Ca) must you order if it will take 50 hours to be delivered to you from the nuclear facility where it is prepared?
4.53 days x 24 hrs/day = 108.72 hrs
50/108.72 = 0.4599 half-lives
(1/2)^0.4599 = 0.727
3.25 μg / 0.727 = 4.47 μg
Am I doing something wrong? All the ways I've seen to do this type of problem lead me to the same answer, but it says it's incorrect.
I don't think so but you haven't finished, read the question carefully!
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
